You infrared my mind.
Unread 10-01-2017, 18:54
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Diamond Plate?
Originally Posted by rich2202 View Post
You would have to know that the Alliance Wall is made of Diamond Plate. I searched the Basic Field, Field Assembly, and Field Components drawings for "diamond" and did not find any hits.
You're looking in all the wrong places. It's right in the Rules:
3.11.1 PLAYER STATION A PLAYER STATION is one (1) of three (3) assigned positions in an ALLIANCE WALL from where a DRIVE TEAM operates their ROBOT. Each PLAYER STATION is made from a 3 ft. (~91 cm) tall diamond plate panel base topped with a 3 ft. 6 in. (~107 cm) tall transparent plastic panel. An aluminum shelf is attached to each PLAYER STATION to support the DRIVE TEAM’S OPERATOR CONSOLE. The shelf is 5 ft. 9 in. (~175 cm) wide and 1 ft. (~30 cm) deep. There is a 4 ft. 6 in. (~137 cm) long by 2 in. (nominal) wide strip of hook-and-loop tape (“loop” side) along the center of the support shelf that may be used to secure the OPERATOR CONSOLE to the shelf.
(emphasis mine)
(since 2004)
Unread 10-01-2017, 18:58
Philip Arola's Avatar
Philip Arola Philip Arola is offline
You can check out any time you like
AKA: KG7VAM
FRC #2898 (The Flying Hedgehogs), FRC #1510 (Wildcats)
Philip Arola is an unknown quantity at this point
Re: Diamond Plate?
Even further to your point, the Stronghold manual has identical wording.
A PLAYER STATION is one (1) of three (3) assigned positions behind a CASTLE WALL from where a
DRIVE TEAM operates their ROBOT. Each PLAYER STATION is made from a 3 ft. tall diamond plate
panel base topped with a 3 ft. 6 in. tall transparent plastic panel. An aluminum shelf is attached to
wide and 1 ft. deep. There is a 4 ft. 6 in. long by 2 in. wide strip of hook-and-loop tape (“loop” side)
shelf.
It's just referring to diamond patterned steel.
Cunningham's Law: The best way to get the right answer on the Internet is not to ask a question, it's to post the wrong answer.
