Go to Post You have the rest of your life to play video games. Time at an FRC tournament is precious. Use it wisely. - gblake [more]
Unread 10-01-2017, 19:14
kylemikableh's Avatar
kylemikableh kylemikableh is offline
FRC #1672 (Robo T-Birds)
Rookie Year: 2016
kylemikableh is an unknown quantity at this point
Offence on the airship?
After much thought and searching the forums, nobody has mention a strategy evolving slowing down the rate at which the pilots process the gears (that I could find anyway). The reason I bring this up is because I notice that the gears are all dependent on your pilots and their speed. I was wondering if anybody had ideas/methods that could legally make the job of a pilot for the other team much more difficult/impossible?
Kyle -- Lead Programmer of FRC Team 1672.
Need help with programming? Swift, PHP, MySQL, HTML, Pyton
"Did I ever tell you the definition of insanity? Insanity is building the same robot everybody else does, expecting to win"
Unread 10-01-2017, 19:19
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Offence on the airship?
Technically I haven't seen any rule against stealing a gear off of a lift but an unattended gear should be rare and will be hard to get from the angles involved.
Unread 10-01-2017, 19:35
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
I am curious as to what strategies you are considering. Other than taking a Gear off of an unattended Lift or knocking a Gear off a Lift as the Human Player pulls it up, I don't know of any strategies that could be implemented.
Unread 10-01-2017, 20:03
Rookie Year: 2016
That is the thing, I feel like there definitely is a strategy that can cause problems for pilots, I mean why else is there a specific way to get fuel out of the airship if they are not meant to be there in the first place? Or even better, why does the airship not have protection from the field waist-up?
Unread 10-01-2017, 21:23
RockRGI RockRGI is offline
FRC #0447 (Team Roboto)
Rookie Year: 2016
RockRGI is an unknown quantity at this point
See Rule 7.5
G25. AIRSHIPS run on steam, not FUEL. ROBOTS may not intentionally put FUEL in an AIRSHIP.
Violation: YELLOW CARD.
G26. If you’re going to deliver GEARS, you have to use a LIFT. Any GEAR transferred to a PILOT during the MATCH must be done so via a LIFT.
Violation: TECH FOUL and a YELLOW CARD.
That pretty much makes messing with the Pilots using game pieces out.
Unread 10-01-2017, 21:27
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
I guess we'll have to revert to aiming lasers at their retinas. Just kidding. Please don't do that.
Unread 10-01-2017, 23:55
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
See Rule 7.5
So pelting the pilots with gears shot at high speed is out.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 11-01-2017, 00:00
dmaggio744's Avatar
dmaggio744 dmaggio744 is offline
Steely Eyed Missile Man
AKA: Drew Maggio
FRC #2869 (Regal Eagles)
Rookie Year: 2015
dmaggio744 is on a distinguished road
I'd imagine FIRST has though of every way to keep robots from remotely affecting pilots from doing their job for sheer safety. Clever thinking, but dangerous, and super illegal.
Unread 11-01-2017, 00:59
EricH EricH is online now
It's called "missed shot". Think about this scenario: A robot is parked by the Launchpad's Hopper, draining shots like crazy, and gets hit by an opponent, changing the aim. Suddenly Fuel is hitting Rotors and dropping into the Airship.
That would also be why G25 specifies "intentionally".
Just about any method that I can think of violates S03, G25, and/or G26.
Unread 11-01-2017, 09:56
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
For the sake of common sense and decency, these are high school kids. Putting them in the middle of the field is already a big step towards potential risks. FIRST has already banned launching fuel into the airship, but please don't try to think of ways to circumvent that rule. From a safety standpoint, and equally important just from a common sense standpoint, don't torment these high schoolers in the middle of the field. Winning a match simply isn't worth it.
Unread 11-01-2017, 12:09
Robonut
AKA: Mr. Lam
Rookie Year: 2015
Maybe park next to the airship and blast some Rick Astley at them.
Unread 11-01-2017, 12:17
ClayTownR ClayTownR is offline
FRC #0100
ClayTownR is a jewel in the roughClayTownR is a jewel in the roughClayTownR is a jewel in the roughClayTownR is a jewel in the rough
R07B though
Gesendet von iPhone mit Tapatalk
Unread 11-01-2017, 12:26
Fields's Avatar
Fields Fields is offline
Classic
Rookie Year: 2015
Fields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to all
Messing with the pilots will be pretty much non-existent.
From a background standpoint, anything you do to interact with the pilot will be limited just for safety. Even lifting gears from a robot is on the fence and could possibly change down the road.
From a driver standpoint, the lifts are on the sides of the airship FACING the alliance color. This means you have no visibility aside from what you see in your slightly delayed camera. Blind driving into a robot trying to line up to deliver a gear is one thing. Trying to knock a gear off before the pilot pulls it up is a whole nother can-o-worms.
Unread 11-01-2017, 14:59
VIKotic Dave VIKotic Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
VIKotic Dave is an unknown quantity at this point
I agree !
