Go to Post That wiring job is so sexy I would date it. - RoboChair [more]
Unread 10-01-2017, 11:49
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rope Rule question
Before I ask on the Q&A, what are your thoughts on:
Rope - Loop
I04 When “measured end to end” for a looped rope, is that “as looped”, or before looping? Can I have a 10 ft rope, when looped, is only 7 feet long?
Rope - DAVITS
I04 Is there a limit on how much of the rope can be above the DAVITS point? For purposes of min/max length, should it be measured from the DAVITS point, and not the “end “?
If I wanted 2 feet to hang below the DAVITS point, I could put 3 feet of the Rope above the DAVITS Interface.
Unread 10-01-2017, 12:05
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Rope Rule question
Rope - Loop
Rope - DAVITS
This is also something I am interested in. The bit that gets me in "be designed/configured to be at least 5ft. 3 in. / to not exceed a length of 8 ft." is the "configured" bit. This says to me that knots and loops might not count toward length (as if you were following individual rope fibers down the rope length), but rather if you just stretch your rope out, whatever ruler length next to it you need is the length (maybe).
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
i think it is as-looped. if you change the looping, it needs reinspection, so it must be inspected in final form.
It is true there does not appear to be a spec for the length between the davit end and the davit knot. I expect this to be clarified.
Unread 10-01-2017, 14:43
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Pretty sure the intent of the length limit is for while its hanging from davit. They don't want you having a rope that interferes with an opponents ability to leave their retrieval zone.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 10-01-2017, 14:50
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
I haven't done the math, but there is a minimum length to get the ROPE to attach to the AIRSHIP.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 10-01-2017, 14:54
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
I think the minimum length is such that hanging from the davit, it should just reach the top of a tall robot. the maximum length is such that it might just brush the floor.
Unread 10-01-2017, 16:48
tim-tim's Avatar
AKA: Tim Miedzinski
Understood. I was trying to give some input to the question of where is the length of rope measured from. I should have probably worded it such that it:
The ROPE must be able to reach the hook and loop strap on the AIRSHIP. I don't know what this length is (Davit --> Launch Pad --> Hook&Loop Strap).
The RoboBees
Unread 10-01-2017, 17:15
From page 20, it looks like the DAVIT is 6'7" from the floor. There is a minor horizontal portion of the DAVIT.
Per I04, page 100, the rope length is 5'3" to 8'0". which means it can be about 1'4" (16 inches) off the floor to 1'5" dragging on the floor.
So, any robot should be able to reach the rope.
Unread 10-01-2017, 20:39
BethMo BethMo is offline
FRC #0948 (NRG (Newport Robotics Group))
BethMo has much to be proud ofBethMo has much to be proud ofBethMo has much to be proud ofBethMo has much to be proud ofBethMo has much to be proud ofBethMo has much to be proud ofBethMo has much to be proud ofBethMo has much to be proud ofBethMo has much to be proud ofBethMo has much to be proud of
They're not going to require teams to undo all their elaborate rope-knotting for inspection. Therefore, the length requirement must be with knots.
Unread 10-01-2017, 20:52
logank013's Avatar
logank013 logank013 is offline
System.out.println("Ready!");
AKA: Logan Kreisher
FRC #0234 (Cyber Blue)
Team Role: Scout
Rookie Year: 2015
logank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant future
Actually, looking at the drawings here, the rope starts at 4'10' of the ground + maybe 2 inches for where the rope will set on top of the touchpad. It appears the shortest rope will still have at least 3 inches on the ground.
Cyber Blue Season 2015
IN Indy District Chairman's Award Winner | IN Kokomo District Event Winner (With 135 and 3865)
IN Purdue District Event Winner (With 1024 and 2197) | IN District Championship Winner (With 1024 and 292)
WORLDS:
Archimedes Rank 3 After Quals. | Alliance #3 Captain
Archimedes Division Semi-Finalist (With 503,188, and 836)
Scouting is life. Excel is friend, not foe.
Unread 10-01-2017, 23:08
Squillo Squillo is offline
AKA: Cynthia Hannah-White
FRC #2465 (Kauaibots)
Squillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant future
I don't think so. The touchpad is 4'10" from the floor, but the DAVIT is higher than that (the rope runs down through the middle of the touchpad assembly). I think the davit is 6'7" from the floor.
Unread 10-01-2017, 23:17
logank013's Avatar
AKA: Logan Kreisher
Team Role: Scout
Rookie Year: 2015
Wow... thanks. We built one of these in our lab and I don't think we realized it was secured to the Davit. We were under the impression it was secured at 4' 10" right above the plate but now I see that isn't the case. I'll bring this up tomorrow to my team. Thanks.
WORLDS:
