Go to Post I always viewed Gracious Professionalism as "I may not agree with you or even like you but we need to work together to solve this problem. So let's get to work!" - Koko Ed [more]
Unread 10-01-2017, 22:17
deltlead deltlead is offline
FRC #2655
deltlead is an unknown quantity at this point
Question on R02. Is it possible to extend past the frame perimeter?
While working on the design for our ball hopper, we were trying to find ways to maximize our volume. One concept that was talked about was making the hopper collapse outwards after the start of the match, increasing its volume.
Essentially our design would be Lexan panels connected at the corners by mesh netting. After the start of the match, a pin would be pulled allowing the three panels to fall outwards past the frame perimeter but not past the edge of the bumpers, so it would still be within the robot's maximum volume.
Our concern is the interpretation of rule R01, page 63 of the game manual:
"The ROBOT (excluding BUMPERS) must have a FRAME PERIMETER, contained within the BUMPER ZONE, that is comprised of fixed, non-articulated structural elements of the ROBOT. Minor protrusions no greater than ¼ in. (~6.3 mm) such as bolt heads, fastener ends, weld beads, and rivets are not considered part of the FRAME PERIMETER."
.. of rule R02, page 64 of the game manual:
"In the STARTING CONFIGURATION (the physical configuration in which a ROBOT starts a MATCH), no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER, with the exception of its BUMPERS and minor protrusions such as bolt heads, fastener ends, rivets, etc."
...and of rule R03, page 64 of the game manual:
"Maximum ROBOT size, including BUMPERS and all extensions, must be constrained to one of two volumes:
A. 36 in. by 40 in. by 24 in. tall (~91 cm by 101 cm by 60 cm tall).
B. 30 in. by 32 in. by 36 in. tall (~76 cm by 81 cm by 91 cm tall).
The ROBOT must remain constrained to the maximum inspected volume at all times during the MATCH (i.e. A ROBOT may not switch between volume A and volume B without being reinspected)."
Since our design is made of articulating, non-structural elements it is not considered part of the frame perimeter. And our design's starting configuration keeps all parts of the robot contained within its frame perimeter, it should be legal to extend past the frame during the match as long as we keep it within the maximum build volume.
Can anyone confirm this is true? There was no clarification in the team update on this.
Unread 10-01-2017, 22:36
Harrison.Smith Harrison.Smith is offline
Business, CAD, Mechanical
Harrison.Smith will become famous soon enough
Re: Question on R02. Is it possible to extend past the frame perimeter?
You are correct.
G04 - Don’t overextend yourself. A ROBOT may not exceed the volume for which it passed Inspection during the MATCH.
“Rest and be thankful.” — William Wadsworth
Team 1296: 2014 - 2016
Unread 10-01-2017, 22:38
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
It's accurate to say that articulating elements which protrude beyond the frame perimeter during gameplay are legal as long as they remain within the selected volume throughout their range of motion.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
dmorewood's Avatar
dmorewood dmorewood is offline
Lead Designer / Coach
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
dmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nice
From my understanding and interpretation of the rules, this is legal as long as you don't extend outside of your bumpers and start within your frame perimeter. If you want to be absolutely certain before committing to this design though I would submit this to Q&A. I'm sure other people have the exact same question so I'm sure if you ask there will be plenty of people benefitting from the answer.
Unread 10-01-2017, 22:45
seg9585's Avatar
AKA: Eric
Don't extend outside of your bumpers? Which rule says no articulation past the bumpers?
This wouldn't even be a Q&A rule, it's pretty clear that articulation past the bumpers is perfectly legal as long as you always stay within your selected volume.
My FIRST legacy:
Unread 11-01-2017, 11:29
FRC #2655
Thanks everyone.
Unread 11-01-2017, 14:54
VIKotic Dave VIKotic Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
VIKotic Dave is an unknown quantity at this point
See Q4 FIRST Q&A
