Go to Post Remember to ALWAYS use physics in engineering discussions. There is really no room for "feelings" in this sort of thing. - JVN [more]
Unread 10-01-2017, 19:52
Mr_Moko's Avatar
Mr_Moko Mr_Moko is offline
[INSERT TITLE HERE]
AKA: Jaye
FRC #2729 (STORM Robotics)
Mr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond repute
Post A Quick Poll on Scoring Preferences
Hi everyone, I wanted to do a quick poll on if your team I'd going to prefer scoring via the fuel/balls, the gears or both!
Please do this poll if you don't mind disclosing that information
Poll HERE
Im also curious of everyone's personal opinions on these matters and would love to see them in this thread!
CLAP CLAP WHOOSH!
Co-Founder of the LGBT+ of FIRST blog (2016)
"But.. How can we break it so it doesn't break later?"
"Schade!?"
Unread 10-01-2017, 21:13
pipsqueaker pipsqueaker is offline
FRC #1124
pipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to all
Re: A Quick Poll on Scoring Preferences
I think there's a lot to be said for a dedicated ball scorer to be honest.
Gears will give you, in elims, 260 points. A good ball scorer should probably be cycling 150 balls (50 points per cycle), meaning they'll have to cycle 5 times over the course of the match.
My measured estimate is that getting the 150 balls from the hoppers will take 15s. With 120s in the match for teleop, that leaves you needing to cycle every 23s. Getting your pieces from the loading lanes will probably take 7s. Allowing 8s for transit time means your shooter will have to be capable of firing off 150 balls in 8 seconds, or about 19 balls per second.
Call me crazy, but I think 19 balls a second is doable.
Of course, I'm not accounting for defense here, but gear bots will be hurt more by defense than shooters because if they come up even one gear short MORE THAN HALF of the point value they bring will be annihilated.
Shooters wont suffer from that. If in a match a shooter 90% of what it aims to do, it will score 90% of the points. If a gear bot achieves 90% of its goal, it will score 45% of the points.
My gut says that dedicated gear bots without shooters will be competitive at high levels of play, and that good shooters (with the specs I described) with no gear handling-capacity will become incredibly strong as the game progresses
Unread 10-01-2017, 22:25
TrenchFoot TrenchFoot is offline
FRC #2549
TrenchFoot is an unknown quantity at this point
So I might be misunderstanding what you mean, but are you saying that your plan is to get all 150 pieces of fuel per cycle? Because only 50 fuel can even fit in the legal volume, and that's without a robot...
Unread 10-01-2017, 22:45
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
19 balls per second into a boiler that can process 8-10 per second?
Software Mentor
3853 Pridetronics[
Unread 10-01-2017, 22:52
pabeekm's Avatar
pabeekm pabeekm is offline
Master of typos
AKA: Patricia
FRC #0900 (Zebracorns)
pabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond repute
Ummm... can you post the math on that please?
Unread 11-01-2017, 00:04
FRC #1124
Processing speed refers to how fast the balls are scored, it has nothing to do with how fast a robot spits fuel into the boiler itself.
If you're talking about the hoppers, what I envision is something like this- human player dumps a return bin of 50 balls into the container, robot hits wall to let the boulders spill, backs up, and repeat.
If you're talking about the robot volume, you're flat out wrong
