Go to Post Seems decretive bumpers are the new rage now. I couldn't stand making them once, never mind twice. - Gregor [more]
Unread 10-01-2017, 21:40
RaskorTheWise RaskorTheWise is offline
AKA: Noah Gersh
FRC #2551 (Penguin Empire)
Rookie Year: 2015
RaskorTheWise is an unknown quantity at this point
Code builds, deploys, and robot teleop enables, but nothing works.
Hello all, hopefully your builds and programs have been going well! Unfortunately, my team seems to have run into an issue where when we use nearly identical code to our robot from last year, we can't actually use our joysticks to drive this year's robot. The wiring is OK, and fits the parameters set in the code. Additionally, the current drive station setup works with the aforementioned Stronghold robot. However, despite enabling it, we cannot change our Spark motor controllers whatsoever. They work mechanically, but the code won't update in in teleop.
I have some code here.
Note that the commented out code is simply there because we haven't added any pneumatics or encoders yet.
Thanks for any help.
Unread 10-01-2017, 23:00
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: Code builds, deploys, and robot teleop enables, but nothing works.
I would change line 75 to be:
daedalusDrive = new RobotDrive(leftDriveSpark, rightDriveSpark),
Also, what is the status color/pattern of the status lights on the Sparks when you enable the robot?
Unread 10-01-2017, 23:10
AKA: Noah Gersh
Rookie Year: 2015
That's the original code, and after switching it back we got it working. Because whoever wired it swapped the direction of the PWM in the Sparks.
Thanks though!
Unread 14-01-2017, 10:59
frodobaggins05's Avatar
frodobaggins05 frodobaggins05 is offline
AKA: Wiring Specialist
FRC #2783
Team Role: Electrical
Rookie Year: 2016
frodobaggins05 is infamous around these partsfrodobaggins05 is infamous around these partsfrodobaggins05 is infamous around these parts
Are you absolutely positive that you're wiring is ok?
