Go to Post So remember, we may be envious of teams who can do water jet cutting and has every possible monetary and engineering advantage, but there are many more people who are envious of every team who has a chance to compete. - Rombus [more]
Unread 10-01-2017, 17:22
Eric_Dao Eric_Dao is offline
FRC #6397
Rookie Year: 2017
Eric_Dao is an unknown quantity at this point
Ethernet from Radio to RoboRIO?
Is there supposed to be a way to connect the Radio to the RoboRIO? I plugged in an ethernet cable from the Radio to the RoboRIO and I got communications up and running in the DS. Is this the correct way to do it?
Unread 10-01-2017, 17:31
Levi Madden's Avatar
Levi Madden Levi Madden is offline
Student
FRC #1987
Levi Madden is on a distinguished road
Re: Ethernet from Radio to RoboRIO?
Yes
Unread 10-01-2017, 17:32
FRC #6397
Rookie Year: 2017
Originally Posted by Levi Madden View Post
Yes
Thank you
Unread 10-01-2017, 18:35
Philip Arola's Avatar
Philip Arola Philip Arola is offline
You can check out any time you like
AKA: KG7VAM
FRC #2898 (The Flying Hedgehogs), FRC #1510 (Wildcats)
Philip Arola is an unknown quantity at this point
This is the most basic and most foolproof method. If you begin to implement more features, such as a network camera or a co-processor (perhaps for CV), then you want an unmanaged switch like this one. With this, simply plug the all the devices into it; there shouldn't be any specific port assignments.
Cunningham's Law: The best way to get the right answer on the Internet is not to ask a question, it's to post the wrong answer.
Unread 10-01-2017, 23:08
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
Agreed, the only thing i would suggest is roboRio direct to Wireless and then personally I would use one of these switches for other things such as a computer to do vision processing, IP camera etc.
https://www.amazon.com/NETGEAR-ProSA...0000BVYT3?th=1
That way your main robot functions wont get knocked out if the switch has any issues or loses power etc.
Unread 10-01-2017, 23:20
Make sure to comply with R63.
Unread 11-01-2017, 17:33
acastagna acastagna is offline
FRC #1493
acastagna is an unknown quantity at this point
If we are using a raspberry pi for vision processing, what would be the benefit of the switch over Ethernet cable from each to the radio?
Unread 11-01-2017, 17:46
bobbysq bobbysq is online now
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
More ports (physical ports, not network ports) are made available. Then you can plug in a computer to program or test at competition.
