Go to Post I am specifically looking for Rhode Island, Hawaii, New Hampshire, Nevada, California, Florida, ... oh heck, all of the rest. - Rosiebotboss [more]
Unread 10-01-2017, 23:24
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Polycord Conveyor Belts
Originally Posted by Knufire View Post
McMaster 6075K15
How have you joined it. do you need a $450 kit to do it?
Unread 10-01-2017, 23:28
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
It's far easier to join that round belt. My favorite way is to use a hot plate (a pan on a stove works well too) set to max power. Melt the ends and then press them together. Once the urethane solidifies wait at least 10 minutes before applying tension. You can melt the faces of the belt together too if you have trouble with the ends. I've never had a properly joined belt fail.
2016: FRC 865 Mentor
Unread 10-01-2017, 23:31
Billfred's Avatar
Billfred Billfred is offline
The 2815 method:
Measure, cut about 3-5% short (IIRC).
Set both ends in a piece of angle, with a second piece of metal to steady it.
Melt with a small torch or lighter, press together.
Clamp tight with another piece of angle for more straightness.
Wait 10 minutes.
Try to break it by stretching; if the belt fails, you did it wrong. Try again.
Unread 10-01-2017, 23:33
Knufire Knufire is offline
We made a custom aluminum tip for a large 240W soldering gun and a hinged block with a slot. Heated the ends up, pushed them together in the slot and close the top of the block on them to keep them aligned. Wait until they cool and remove.
The block (along with two tiny vice grips and some other misc hardware) made a nice little toolkit that allowed us to weld these together on the robot under tension. Fixing broken belts without having to remove the roller was a big plus.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
