Go to Post 15 thread derailment points - EmileH [more]
Go Back   Chief Delphi > Technical > CAD
Unread 10-01-2017, 23:45
Massako Massako is offline
FRC #5725 (Cerberus)
Rookie Year: 2015
Massako is an unknown quantity at this point
Our 2017 drive train
our main idea for this drive train was to increase cycle times for gears and to allow for a super maneuverable robot. Let me know what you all think and if you have any suggestions Thanks.
Unread 10-01-2017, 23:49
Rookie Year: 2015
Re: Our 2017 drive train
http://imgur.com/SD4SlQf
Unread 10-01-2017, 23:54
Jared Russell's Avatar
Taking a year (mostly) off
Others who have implemented this type of drive in FRC have strongly recommended ensuring that your strafe wheel is on some sort of a suspension to ensure it receives enough normal force to be effective on imperfect floors.
Unread 10-01-2017, 23:55
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
I'd suggest switching out those shaft clamps for 1/4-20 button heads with a washer in tapped holes on the ends of the hex shaft. Thunderhex stock comes pre drilled with the proper size hole for a 1/4-20 tap if you don't have a lathe. This will save some weight and cost. You could probably increase the distance between your wheels too which is always good thing.
2016: FRC 865 Mentor
Unread 10-01-2017, 23:58
Rookie Year: 2015
Thanks yea. We already have over 50 of those hex shaft clamps and as well as the hex shaft but no lathe. I would like to do that but for simplicity sake its much easier since we don't have a lathe. I really appreciate your comment though.
Thanks
Unread 11-01-2017, 00:04
Rookie Year: 2015
do you know anyway of doing that that would be cost effective and easy to manufacture? That's the only reason we haven't adapted that and are ok if it is not perfect. it is primarily there for slight assistance with aligning with the gear lift. we have looked at some implementations of such a method but concluded it would be to difficult for our ability with manufacturing.
Thanks
Unread 11-01-2017, 00:06
ollien ollien is offline
FRC #5202
ollien is just really niceollien is just really niceollien is just really niceollien is just really nice
Thanks
The nice thing about thunderhex is that it already has the hole, ready to be tapped for 1/4-20. You just need to tap it. No lathe required.
Unread 11-01-2017, 00:09
Rookie Year: 2015
Ok thanks. I will discuss it with my team tomorrow.
Unread 11-01-2017, 00:16
mman1506's Avatar
no team (WARP7)
Thanks
You could try using a VersaDrop module. The pneumatic cylinder will act as a air spring to give you some suspension travel and you could retract it if necessary. If you add a secondary air pressure regulator you can adjust the air pressure until you are happy with the amount of force it pushes against ground.
Unread 11-01-2017, 00:56
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The other nice thing about thunderhex is it fits better in thunder hex bearings than hex does in hex bearings. And doesn't have off-center holes like many hex bearings. And the thunderhex bearings aren't likely to crack and split under shock loads like some hex bearings. And you can use round shaft spacers instead of hex, and....
Unread 11-01-2017, 02:01
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Thanks
Built one of these back in 2008. I can absolutely confirm that you need this feature -- not having it basically wrecked that robot. Middle wheel was ever-so-slightly lower than the outer four, and it could not drive straight, in any direction, to save its life. In hindsight, we should have pulled the middle wheel out after the first match and never looked back, instead of trying to fight it all event long.
Easiest and most foolproof way I can think of to do it COTS would be a VersaDrop module with only one wheel, spring loaded downwards. Alternatively, you could try building something like 148's decadrive center module out of a series of versablocks.
Unread 11-01-2017, 07:22
Thingem3376 Thingem3376 is offline
FRC #5243
Thingem3376 is an unknown quantity at this point
Thanks
In 2015 my team was able to build an H-Drive out of two AM14U bots. All we had then were the basic tools, chopsaw, bandsaw, and a drill press as well as an assortment of hand tools. For our suspension we took a bunch of thin 1/16" washer and can't them around the shank of a 1/2" And stacked them in between where the H-drive met the chassis, like leaf springs in a truck. The hardest part about this drive train is figuring how much you want that center wheel to influence normal driving, if you lower the center wheel to much driving becomes very difficult, if you put it too high you find that you can't strafe. In the end we ended up having to adjust height at each of our competitions because the fields are much more uneven than they seem.
Unread 11-01-2017, 12:19
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
My team built a very simple spring adjusted prototype this past offseason.
If I remember, I will post pictures or our system tonight after our build session.
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2017: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
Unread 15-01-2017, 02:57
ImMoMo's Avatar
ImMoMo ImMoMo is offline
AKA: Mo
FRC #2559 (Normality Zero)
ImMoMo is an unknown quantity at this point
Lovely design, I'm a fan of the clamp on gearboxes.
We too are using them this year, and I was wondering what kind of encoder you are using for this set up?
We ordered the CIMCoder, it seems like a good option, however, I'm worried about clearances with with pinon and driven gear.
Also, have you considered adding a pulley/sprocket reduction... although you would probably have to move a few things around.
