Go to Post everybody wants a piece of success! - Taylor [more]
Unread 10-01-2017, 23:35
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Connecting two ends of pneumatic tubing?
Any tips on fusing two ends of pneumatic tubing for our intake? We found these and was wondering if anyone has experience with them?
Unread 10-01-2017, 23:49
JR0405's Avatar
JR0405 JR0405 is offline
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
Re: Connecting two ends of pneumatic tubing?
What do you mean by for your intake, is there a reason as to why you can't cut a piece to be the desired length?
#StaySavage
Unread 10-01-2017, 23:53
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
I assume they want to fuse the two ends to make a continuous loop, and use the tubing like a belt.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 11-01-2017, 00:06
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
wouldn't use pneumatic tubing use poly cord
http://www.wcproducts.net/catalogsea...lt/?q=polycord
Unread 11-01-2017, 01:35
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Pneumatic tubing with barbed connectors might work (such as on a prototype), but for your competition robot you will likely have more success using polycord.
Polycord, also known by the more generic names of round belting or urethane belting, is available in three types: hollow round, solid round, and flat belts. The hollow core version uses barbed connectors, and is generally not as durable as the solid or flat belt varieties. For the solid and flat belting, you use heat to melt and fuse the ends of the belt together.
Both round versions work on pulleys that have grooves in them to keep the belts aligned. The flat belt works on a pulley that (seemingly counter-intuitively at first glance) actually runs on a raised ridge. This ridge is actually what keeps the flat belt aligned and prevents it from "walking" down your pulley (the difference in tangential speed between the raised section and the lower section is what keeps the flat belt aligned on the raised ridge).
For fusing solid polycord, you can use a lighter or small torch to melt the ends of the cord (use the heat to melt, don't catch the polycord on fire), then press the two ends together using the inside of aluminum angle to keep the cords aligned.
Art Dutra IV
世上无难事,只怕有心人.
Unread 11-01-2017, 08:25
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Yeah I +1 to that. My team had a habasit sponsorship years ago, and we used this material for our 2012 intake. It was very similar to what you may see this year. Our bot utilized an elevator intake, which then dropped gamepieces into a gravity-fed shooter. The polycord was wrapped around rubber coated shafts (grooves for the polycords were cut into the rubber, allowing them to find their places, and helping them to stay on track.
[Edit] I would like to add that we used round polycord.
Unread 11-01-2017, 09:56
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Keep in mind pneumatic tube comes in a wide variety of plastics. Some would be useful in this application, some not so much. Better to use polycord as others have said.
Unread 11-01-2017, 10:12
pipsqueaker pipsqueaker is offline
FRC #1124
pipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to all
Use polycord, pneumatic tubing isn't nearly as flexible as an intake would require it to be
The plugs are good, but in my experience with polycord they're not immune to failing.
Some plastic-metal superglue will do the trick though. I like to use a bit to bond the plug to the tube, mate the two ends, and then glue those mated ends together as well
Unread 11-01-2017, 12:22
catmanjake catmanjake is offline
FRC #4009
catmanjake is an unknown quantity at this point
when I look at this website, all I see are pulleys.
Have a website showing poly cord?
Unread 11-01-2017, 13:16
http://www.durabelt.com/polycord.php
Unread 11-01-2017, 14:58
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
http://www.wcproducts.net/WCP-0129
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
