Go to Post Probably planning on milling the bumpers out of solid pool noodle stock, too. Ever wonder how they drill that hole down the middle of pool noodles? ;) - Bill_B [more]
Unread 11-01-2017, 08:05
UberMathNerd UberMathNerd is offline
FRC #5407 (Wolf Pack Robotics 5407)
Rookie Year: 2016
UberMathNerd is an unknown quantity at this point
Example Code Error - Getting Started
Hey,
I'm a new coach. I am using Java through Eclipse and I tried to load the first example program called "Getting Started" but
1) the first line "package org.usfirst.frc.team5407.robot;" comes up with an error "The type java.lang.Object cannot be resolved. It is indirectly referenced from required .class files"
2) and the class declaration "public class Robot extends IterativeRobot" gives another error "implicit super constructor Object() is undefined for default constructor. Must define an explicit constructor"
any ideas how to fix that? I haven't touched the code, just opened the example through file>new>project
thanks!
-Jordan
Unread 11-01-2017, 09:02
Re: Example Code Error - Getting Started
That sounds like it may not be able to find the JDK. Make sure to check the settings described in "Setting up the JDK in eclipse (Java teams only)" on this page: https://wpilib.screenstepslive.com/s...eclipse-c-java
Specifically, note how it points to jdk for location, not JRE (even though the left column text says jre).
Unread 11-01-2017, 09:43
Rookie Year: 2016
Thanks for the idea. I checked and it looks to me like the JKD is installed. Here is a screenshot
Unread 11-01-2017, 12:20
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
It looks like your image failed to upload. Can you try again?
Unread 11-01-2017, 16:51
Rookie Year: 2016
Does that work?
https://s30.postimg.org/ozrm23n1d/Sc...9_40_47_AM.png
Unread 11-01-2017, 16:52
Rookie Year: 2016
Ok, an added complication. I started another project using the Ultrasonic example and that one has no errors.
