Go to Post All those crazy teenagers walking around Atlanta trying to "Save the world" looking like gang members with their attire. - BrendanB [more]
Unread 11-01-2017, 09:50
stiny861 stiny861 is offline
FRC #3055
stiny861 is an unknown quantity at this point
Re: Connecting Eclipse to Github
I was able to figure it out. Turns out I was going about it backwards. I was trying to directly import a Git project, which in this case was last years code, and then somehow convert it to a WPIlib project. You actually need to do it the other way around. Create the WPIlib project, then under the Team section of the project, create a repository and then link that repo to github. Works like a dream now. I can give more precise instructions if anyone is interested.
Unread 11-01-2017, 10:04
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
We've never needed to jump through hoops like that to get a project imported. I wonder why it needs to be like that for you.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 11-01-2017, 10:10
FRC #3055
I have a feeling it was because of the nature of eclipse. When you import a project directly from a Git repo, it is only going to pull what was in that repo. I did not have the ability to do a reindex or anything like that to even add in the includes. I think it is intended for fully self-contained codesets that do not include any additional components on your computer, which in this case was the WPIlib 2017 code. I had to simply reverse the process and start as a wpilib codeset, then add the repo onto it to update the needed files. In this case, we don't need to include the includes as it is a needed prereq to even work with the code in the first place.
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
I've also always had to make a new project and then import it. Maybe it's because we .gitignore most IDE files?
Unread 11-01-2017, 11:25
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
That's a good point. Don't gitignore .project or .classpath or .cproject
