Go to Post I too can find a method with correlation bias by applying a pattern to most datasets! - BrennanB [more]
Unread 11-01-2017, 10:04
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Connecting Eclipse to Github
Originally Posted by stiny861 View Post
I was able to figure it out. Turns out I was going about it backwards. I was trying to directly import a Git project, which in this case was last years code, and then somehow convert it to a WPIlib project. You actually need to do it the other way around. Create the WPIlib project, then under the Team section of the project, create a repository and then link that repo to github. Works like a dream now. I can give more precise instructions if anyone is interested.
We've never needed to jump through hoops like that to get a project imported. I wonder why it needs to be like that for you.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
