Go to Post If you can't be bothered to read the Q&A, why are you spending thousands of dollars competing? - Ian Curtis [more]
Unread 11-01-2017, 10:10
stiny861 stiny861 is offline
FRC #3055
stiny861 is an unknown quantity at this point
Re: Connecting Eclipse to Github
I have a feeling it was because of the nature of eclipse. When you import a project directly from a Git repo, it is only going to pull what was in that repo. I did not have the ability to do a reindex or anything like that to even add in the includes. I think it is intended for fully self-contained codesets that do not include any additional components on your computer, which in this case was the WPIlib 2017 code. I had to simply reverse the process and start as a wpilib codeset, then add the repo onto it to update the needed files. In this case, we don't need to include the includes as it is a needed prereq to even work with the code in the first place.
