Go to Post Dave, you're going to have quite the motor pool on Mars. :D - skimoose [more]
Unread 11-01-2017, 12:01
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
pic: OMNI Drive
Unread 11-01-2017, 12:03
The Doctor's Avatar
The Doctor The Doctor is offline
Robotics is life
AKA: Hackson
FRC #3216 (MRT)
The Doctor is on a distinguished road
Re: pic: OMNI Drive
Though I've never had direct experience with this, I'm sure it would have many of the main problems associated with mecanum wheels, though probably a bit worse. The main concern is that you'll get pushed around, since omniwheels have so little traction.
If there was no chance of defense, it might be a good idea. However, I get the idea that there will be a lot of pushing this year.
Robots + Python + pentesting == me;
Blog ~ GitHub ~ Keybase
If you have a pressing issue to discuss with me, kik me at slush.puddles since I don't check CD very often.
Unread 11-01-2017, 12:08
Taylor's Avatar
Taylor Taylor is online now
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: pic: OMNI Drive
Disclosure: I have never personally worked with this type of system, but I have seen it used both in person and in video.
When the omniwheels are centered on the frame like this, the robot tends to get tippy in the corners when turning. A way to overcome this is to make the frame low to the ground or 'wheelie bars' in the corners.
Hi!
Unread 11-01-2017, 12:19
Re: pic: OMNI Drive
Originally Posted by pribusin View Post
They thought it could give fast straight drive speeds along the two main axes of the wheels
Kinematically, it will be faster along the diagonals.
Unread 11-01-2017, 12:28
pribusin's Avatar
Uber Alien
AKA: Mike 1
Re: pic: OMNI Drive
How do you figure? Aren't you always losing some forward vector from all four wheels due to all rollers being angled and only part of the rotational vector getting translated into forward motion? I'll give you that you have four wheels propelling rather than two.
Unread 11-01-2017, 12:30
mr_yes mr_yes is offline
FRC #1248 (The TITANium Allies)
mr_yes has a spectacular aura aboutmr_yes has a spectacular aura about
Re: pic: OMNI Drive
Like with a mechanum drive system, one key to this being a viable drive train is lots of practice with it under realistic conditions. Because omniwheel systems drive differently than tank-style, the driver's brain has to be re-trained.
Unread 11-01-2017, 12:34
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: OMNI Drive
You get v1/(2)^1/2 + v2/(2)^1/2=vd, assuming v1=v2, then vd=sqrt(2)*v1
That is to say: the diagonal speed will be ~140% of either pair of wheels' speed.
See:
I imagine that this drive base would be quite tippy given the small base of support. The setup below is more common because the base of support is larger, and the fastest drive speeds are now aligned with the major faces of the chassis.
Unread 11-01-2017, 12:42
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: pic: OMNI Drive
Wheres you Fuel intake? hope you are not relying on Hoppers. I suspect many games within first 30 secs will have all fuel on floor...and going to loading station is a slow process.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 11-01-2017, 12:54
Re: pic: OMNI Drive
Using your argument, how is it possible for a sailboat's speed to exceed the wind speed that is propelling it?
Unread 11-01-2017, 13:16
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: OMNI Drive
If you keep the wheels in the same locations but rotate the chassis 45 degrees (or vice versa), you get what is sometimes referred to as Killough Drive (edit: pictured in post#7). This eliminates (or at least greatly reduces the "tippiness" at the corners. It is also kinematically the same as mecanum.
Unread 11-01-2017, 13:30
Re: pic: OMNI Drive
Not.
Mec fwd/reverse kinematics is same as standard wheel.
Unread 11-01-2017, 13:49
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: pic: OMNI Drive
Not.
You do have to gear the Killough Mecanum ~40% faster to get the same behavior. I should have said similar (same shape, different scale).
I'm not sure what you're saying here. What sort of standard wheel?
Unread 11-01-2017, 16:53
Re: pic: OMNI Drive
omni vs mecanum vs standard wheel chart
Unread 11-01-2017, 17:21
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: OMNI Drive
While each wheel has different kinematics between Omni and mecnanum, as a 4-wheeled system they behave the same. You just swap the "diagonal" behavior in one system for the cardinal directions in the other.
You do have to gear the Killough ~40% faster to get the same behavior. I should have said similar (same shape, different scale).
How do you figure.
Unread 11-01-2017, 18:09
jaweth12@gmail jaweth12@gmail is offline
FRC #0456
jaweth12@gmail has a little shameless behaviour in the past
Re: pic: OMNI Drive
Check this pdf on page 12
http://www.simbotics.org/files/pdf/drivetraindesign.pdf
