Go to Post Careful what words you use here; we take them literally. - DonRotolo [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Old 31-12-2016, 18:23
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
R, OPR, etc
Hello to the rather specific part of the FIRST community I am targeting,
I was reading over OPR calculation and other such calculations in order to calculate offensive contributions and some ideas started to weasel its way into my head, therefore I must pursue them. I should pick up the R language relatively easily, as it seems to share many common elements with Python and Matlab. I was wondering are there some resources that you guys could point me towards to aid with my learning? I am slowly falling deeper end deeper into the statistical analysis rabbit hole and any help to ease the future confusion I may have is greatly appreciated.
Happy New Year!
Skye Leake
My time in FIRST has made me a better person, frankly I don't know where I'd be without it.
2011 Lake Superior Regional Champs (Thanks 2512 & 3747)
2015 Central Illinois Regional Engineering Inspiration Award recipients
2016 Central Illinois Regional Champs (Thanks 2481 & 2220)
Old 31-12-2016, 18:51
Oblarg Oblarg is online now
AKA: Eli Barnett
Re: R, OPR, etc
This textbook is oriented towards psychology students, but is a good introductory textbook for just about anyone:
https://health.adelaide.edu.au/psych.../teaching/lsr/
Be sure to download Rstudio, it's about a billion times easier than using R through the standard shell.
"The breakfast of champions!"
Old 31-12-2016, 18:57
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
Re: R, OPR, etc
One of my housemates went through an entire semester of Biometry working straight from the shell, it made my skin crawl. A proper GUI is a must and was installed mere seconds after I installed R.
[EDIT]
I have been using this website as an introduction. It is geared more towards novice programmers but seems to provide strong overviews of the various components of Rstudio.
Old 31-12-2016, 19:06
Re: R, OPR, etc
https://www.chiefdelphi.com/forums/s...7&postcount=24
Old 31-12-2016, 19:16
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
Re: R, OPR, etc
The plan is to slowly work to that. I have a lot of learning to do. I have bookmarked that thread for later use, thanks for linking it in though.
I have some concerns about my package palette. I am sure I will find what I need in time through trial and error; but is there anything additional packages that may prove generally useful that are basic 'need-to-haves'?
Thanks,
Skye Leake
Old 31-12-2016, 20:17
AKA: Eli Barnett
Re: R, OPR, etc
Thanks,
Skye Leake
ggplot2, because it's far easier to use than the default plotting package once you learn it, and reshape2 are the two I'd say are "need-to-haves."
Old 31-12-2016, 21:23
Re: R, OPR, etc
...I have a lot of learning to do. I have bookmarked that thread for later use, thanks for linking it in though.
I was reading over OPR calculation and other such calculations in order to calculate offensive contributions and some ideas started to weasel its way into my head, therefore I must pursue them... I was wondering are there some resources that you guys could point me towards to aid with my learning?
If you need any links to posts and threads here on CD that explain the math underlying the computation of OPR let me know.
Unread 04-01-2017, 21:01
sirwin sirwin is offline
AKA: Stacy Irwin
FRC #1318 (Issaquah Robotics Society)
Rookie Year: 2016
sirwin is a glorious beacon of lightsirwin is a glorious beacon of lightsirwin is a glorious beacon of lightsirwin is a glorious beacon of lightsirwin is a glorious beacon of lightsirwin is a glorious beacon of light
Re: R, OPR, etc
I'm not sure if you've seen the other thread that addresses R and OPR, but I wrote an R package for downloading and manipulating FRC data in R. You might find it useful to peruse the source code, which is on github. I also have links to the R resources that I used in the Getting Started Guide for the package. Links to everything are at http://irwinsnet.github.io
sirwin
Unread 05-01-2017, 09:47
Re: R, OPR, etc
Originally Posted by sirwin View Post
I'm not sure if you've seen the other thread that addresses R and OPR... Links to everything are at http://irwinsnet.github.io
Great resource Stacy. Thanks for posting that.
FWIW, I linked to your post about that several days ago, and the OP indicated he was aware of it.
For others who may not have seen it yet, there is a short paper here that shows how to use sparse matrix technology in R to speed up OPR computation by a factor of 10 or more.
Unread 05-01-2017, 19:56
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
Re: R, OPR, etc
Fall into that rabbit hole! Learning R will have much bigger payoffs down the road. Many of the best statisticians I know use it and it can be a tremendous work skill to have.
Unread 11-01-2017, 13:08
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
Unhappy Re: R, OPR, etc
I know plenty of languages and I am familiar with the syntax of more than I care to admit, but R is so syntactically different than most... It has some nice bits too, but dang it can be annoying...
[IMG] code is Off
