Go to Post There's a fine line between cockiness and confidence. Confidence is one of the major keys to success and happiness in life. As long as one can carefully stay on the right side of the line, staying connfident while remaining humble, and ego can be quite beneficial. - Karthik [more]
Unread 11-01-2017, 13:44
rich2202 rich2202 is online now
FRC #2202 (BEAST Robotics)
That's a lot of fuel
It just occurred to me: There will be a lot of fuel on the field.
Once the hoppers are dumped, 560 Fuel:
100 Fuel (50 on each side) waiting to be dumped through the loader
300 fuel (50 per bot) moving around the field, or being dumped/shot into the Boiler. Note: Once a bot dumps its load into the boiler, by the time it picks up more fuel, the Boiler will have processed dumped fuel. So you are not likely to have fuel in the bot and boiler at the same time.
That leaves 160 fuel rolling around on the field. Even allowing for 50 overflow on each side, that is 60 fuel rolling around the field.
What's the strategy for dealing with excess fuel behind the Alliance Wall? Do you just dump it on the field? That's better than letting the other alliance dump the overflow fuel into their robots at their Alliance wall.
