Go to Post Next year they should make Roombas the game piece. They're not very effective at vacuuming the rug that's for sure. - Koko Ed [more]
Unread 11-01-2017, 13:44
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
That's a lot of fuel
It just occurred to me: There will be a lot of fuel on the field.
Once the hoppers are dumped, 560 Fuel:
100 Fuel (50 on each side) waiting to be dumped through the loader
300 fuel (50 per bot) moving around the field, or being dumped/shot into the Boiler. Note: Once a bot dumps its load into the boiler, by the time it picks up more fuel, the Boiler will have processed dumped fuel. So you are not likely to have fuel in the bot and boiler at the same time.
That leaves 160 fuel rolling around on the field. Even allowing for 50 overflow on each side, that is 60 fuel rolling around the field.
What's the strategy for dealing with excess fuel behind the Alliance Wall? Do you just dump it on the field? That's better than letting the other alliance dump the overflow fuel into their robots at their Alliance wall.
Unread 11-01-2017, 14:06
WSiggs WSiggs is offline
Pb Programmer
FRC #4908 (Dragons)
WSiggs is on a distinguished road
Re: That's a lot of fuel
Don't forget the extra 20 fuel at each alliance's Return Load Station that is there at the beginning of the match. Also overall even 60 balls over the entire field isn't that much. If there are that few on the ground at a time then it will take a lot of time to go and collect enough to fill your bot.
Unread 11-01-2017, 14:28
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Expect kamikaze bot dumping all fuel in 30 seconds so 560 on floor potential
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 11-01-2017, 14:30
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 11-01-2017, 15:18
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
As usual, Randal has it covered
Unread 11-01-2017, 15:49
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is online now
Dancing Drive Coach
FRC #4967 (That ONE Team)
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
http://www.engineeringtoolbox.com/ci...le-d_1905.html
Have fun, virtual high five to the first person who figures out the surface area of the field, and the even spacing necessary to fit all the balls on the field.
Bonus, how tightly can they be packed, and what percentage of the field does it actually cover?
Unread 11-01-2017, 16:06
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
I estimate that the field is at most 5% covered by fuel.
Unread 11-01-2017, 16:59
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
There's gonna be fuel rolling around the alliance station and loading lanes, as well. You can even so one little fuel go running for his life in one of the field tour videos. Some poor human player is inevitably going to step on the fuel and fall over, probably while carrying a tote full of even more fuel.
Unread 11-01-2017, 17:02
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is online now
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
After doing some rough math, the field can hold approximately 7000 fuel, which means about 10-15% of the field will be covered max.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 11-01-2017, 17:06
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
It is going to be interesting carrying 150 lb robots off a field covered in balls. I pity the field reset people.
Unread 11-01-2017, 17:13
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Simply put, I'm not going to allow myself or my drive crew to lift the robot until all the balls have been cleared. The risk simply isn't worth it.
Unread 11-01-2017, 17:18
CEF CEF is offline
FRC #5607
CEF is an unknown quantity at this point
You're not being very optimistic -- I think you meant "remove the robot from the top of the rope."
Unread 11-01-2017, 17:21
Glacier's Avatar
Glacier Glacier is offline
The Bearded One.....
AKA: Levi Cagle
FRC #3959 (Morgan County Mech Tech)
Team Role: Webmaster
Rookie Year: 2015
Glacier is an unknown quantity at this point
As a third year resetter I pity me too
Sent from my iPhone using Tapatalk
Unread 11-01-2017, 17:22
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
No, I meant lift the robot. I'm not going to have a high school students (or adults) carrying a 150 lb robot off a field with tripping hazards littered around it. I've seen a students' knee buckle while carrying a robot before, and I'm not inviting that possibility again.
Unread 11-01-2017, 17:38
Professional Stat Padder
Oh jeez I hadn't thought about this situation. Hopefully FIRST will have some sort of solution for quickly clearing balls out of the way for week 1 events, because there's no way we can have students carrying robots through a pile of balls.
(2015-Present)
