2017 FRC Events API
Does anyone recall when FIRST first published documentation for Score Details requests to their API for the 2016 game?
I am particularly interested in if the API this year will provide detailed information on gears on the airships, or if we will have to determine this information indirectly based on scored rotors. That would be difficult to do properly because gears and rotors don't have a linear relationship. |
Re: 2017 FRC Events API
I would guess it will only provide scored rotors. From the field tour videos, the sensors in place detect the first gear (nearest the rotor) rotating, not which ones are placed. So I doubt the field will "know" how many are placed.
I hope you are wrong, but I agree that this is the most likely scenario.
The API usually only contains details on things entered in the scoring tablets and FMS during the match. Since the FMS doesn't really care how many gears are delivered, you likely won't see that on the API.
"towerFaceB": "Challenged", "towerFaceC": "None", "towerFaceA": "Challenged", Code:
"tote_count_far": 12, "tote_count_near": 27, |
They're quite responsive. I'm sure they would at least entertain a request for this.
#8
What would be really nice is to get an accurate count of boiler goals. Clearly, as other threads have shown, there is no accurate way of manually scouting those, so an automated solution would be really handy.
#10
That's what the counters in the goals are for.
#11
I'm saying that scouting team members can't get an accurate count of the number of fuel scored. If FIRST exposes this data, we can use it to aid in collecting scouting information. I did realize that the balls weren't counted manually by humans.
#12
The number of balls scored in boilers will almost certainly be exposed by the API. Of course, this wouldn't show which team scored the ball.
#13
Filling in the blank between what an alliance scores and each team does are where some have realized limits of what scout can reasonably observe. I felt reasonably successful applying an OPR calc last year to alliance scores. This year I wonder if scout-generated weights applied to the matches might improve the calculation results. For instance, if only Blue.1 has a high goal scorer, then 100% of that score will be given to them and 0% to Blue.2 and Blue.3. For gears, it would probably help to have the end number of gears scored to remove ambiguity between 7 and 13. They may like having that number too when they are deciding whether to up the number of gears for later competitions. |
#14
FIRST has provided a preliminary 2017 score breakdown on the FRC Events API documentation page: http://docs.frcevents2.apiary.io/#re.../score-details
The available data may be modified during the next two weeks, but this gives us a good sense of what kind of data we will have available. Most notably, no gear information is provided. I am also wondering about the robot1Auto, robot2Auto, and robot3Auto categories. I don't know if robot 1 corresponds to the robot which has drivers in station 1, or the robot that lines up in front of station 1. It looks like the same thing existed last year, so does anyone know what it means? |
