Go to Post The point is that while having the abiltity to find information in a variety of reference sources is a useful skill, it does not replace a good, complete, fundamental knowledge of your subject material. - dlavery [more]
  #31   Spotlight this post!
Unread 11-01-2017, 14:37
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Mecanum vs. Tank Drive?
I'm curious if butterflies and octocanums collect alliance selection dings like straight mecanum. Or is it not relevant because teams willing/capable of these drives are usually pickers?
  #32   Spotlight this post!
Unread 11-01-2017, 14:58
chandrew's Avatar
chandrew chandrew is offline
Strategy Sun Tzu
AKA: Andrew Chan
FRC #1410 (The Kraken)
Team Role: Tactician
chandrew is an unknown quantity at this point
Do you have experience building a mecanum drive? If not, I would definitely build the KOP chassis.
The clear field is great for a mecanum, however you want it done quickly so your drivers can practice driving with defense.
Andrew Chan
Dean's List Semi-Finalist 2016
  #33   Spotlight this post!
Unread 11-01-2017, 16:19
Matt_Boehm_329 Matt_Boehm_329 is offline
FRC #0329
Matt_Boehm_329 has a spectacular aura aboutMatt_Boehm_329 has a spectacular aura about
I think it is easier to do well with Tank, but there is more potential in Mecanum. I also feel that most of what Mecanum can do, Swerve can do better (except module complexity).
  #34   Spotlight this post!
Unread 11-01-2017, 17:32
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
I think the purpose of the butterfly and octocanum is to be the best of both worlds. But what about 2+2? Any opinions about not picking teams with 2+2 drive?
  #35   Spotlight this post!
Unread 11-01-2017, 17:52
Rangel's Avatar
Rangel Rangel is online now
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
We did mecanum wheels twice in our team's existence and both times regretted it. I agree with others that if you need precise alignment in the lateral direction(or any direction really) something is wrong with the mechanism design and not the drivetrain. Even if you do use mechanum to fix that problem, the weight of your robot is not likely to be balanced efficiently and you probably won't have a good enough driver to make mecanum worth it in the first place. Literally the only team that comes to mind that used mecanum drive effectively was 4522 in 2014. There may be a few others that actually pulled it off but they are not the norm. In fact most of the time, teams with mecanum just end up driving it like a tank anyways.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
  #36   Spotlight this post!
Unread 11-01-2017, 17:56
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
We won a regional in 2015 teamed up with a mecanum bot as the #1 seed.
So while we are not opposed to teaming up with a robot that uses it, we are definitely against using mecanum wheels for our own robot.
Tank drives have way more advantages than the pluses for using mecanum.
Mecanums should only be used for intakes!
  #37   Spotlight this post!
Unread 11-01-2017, 18:10
Aren_Hill's Avatar
Build Nifty Things
You mean vectored intake wheels? why would you use them on the ground?
I'm confused
-Aren
A guy who likes robots.
  #38   Spotlight this post!
Unread 11-01-2017, 18:14
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
The advantages of mecanum over a tank drive become largely irrelevant with good manipulator design.
Your mechanisms should not require so much precision that it becomes a basis on which to justify mecanum.
2012 - 2015 : 624 CRyptonite
Team Website
  #39   Spotlight this post!
Unread 11-01-2017, 18:25
RoboChair's Avatar
AKA: Devin Castellucci
I'm confused
-Aren
#VectoredIntakeWheels is now a thing!
12 Years and counting! Over a third of my life has been spent with FRC.
  #40   Spotlight this post!
Unread 11-01-2017, 18:47
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
I'm not going to try to convince you with logic, because it's easy for logic to make the advantages of mecanum look bigger than they are. So here is my testimony having driven in competition gyro stabilized mecanum, swerve drive, and tank drive:
A good drive train should get your robot where it needs to be, reliably, quickly, and easily. The bottom line is that a tank drive gets the bot to point B more reliably, more quickly, and more easily, so there is no real reason to build a mecanum drive.
Just build a tank drive. It will make your season better.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
  #41   Spotlight this post!
Unread 11-01-2017, 19:11
ImMoMo's Avatar
ImMoMo ImMoMo is offline
AKA: Mo
FRC #2559 (Normality Zero)
ImMoMo is an unknown quantity at this point
I advocated against Mecanum drive this year, however the students preferred "maneuverability" to the "reliability" of west coast drive.
Here's my belief: whatever you do, you do it well.
As many people have said before— a good driver can be the decisive factor.. having a mecanum bot that goes 20 ft/s and a driver who knows how to control it... can be amazing for traversing the field and avoiding attacks.
Best of luck this year— let's go team mecanum!
  #42   Spotlight this post!
Unread 11-01-2017, 20:24
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
20fps is pretty fast, unless you have a shifter, consider choosing a slower top speed in order to get higher acceleration.
  #43   Spotlight this post!
Unread 11-01-2017, 20:41
Also, a 20 fps mecanum would probably have very poor fine control, especially for small strafing position adjustments.
  #44   Spotlight this post!
Unread 11-01-2017, 21:15
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
We like mecanum wheels - if it's feels right for the game we'll use them. We have a total of 12 regional wins and 9 of the wins were with mecanum wheels.
  #45   Spotlight this post!
Unread 11-01-2017, 21:23
Lord Basket's Avatar
Lord Basket Lord Basket is offline
President & Drive team coach
AKA: Parker
FRC #1719 (The Umbrella Corporation)
Lord Basket has a spectacular aura aboutLord Basket has a spectacular aura aboutLord Basket has a spectacular aura about
Having a mecanum drive in 2015 was a lot different than having a mecanum drive in most years because there was no defense. 2015 is the exception, not the rule, when it comes to drivetrains.
