Go to Post I like anything that is designed to bounce for up to 10 minutes. Expecially if it lands right side up :) - GregT [more]
Unread 11-01-2017, 19:19
pratprem pratprem is offline
FRC #3482
pratprem is an unknown quantity at this point
Sharp Object Qualification
We were thinking of using a thin sheet of aluminum on our robot which we are not sure if it qualifies as a sharp edge. It is contained within the cutout of our chassis and we were wondering if it was okay to use sheet metal that was extremely thin?
Thanks,
Prat
Team 3482
Unread 11-01-2017, 19:21
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Sharp Object Qualification
If you have the edges against something, it should be fine.
Just think about a student reaching their hand into the robot to check a wire, or other part. If you think there is a chance that they can get jabbed or cut, it is unsafe.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 11-01-2017, 19:42
RoboChair's Avatar
AKA: Devin Castellucci
You can do really thin sheet metal, no problem. If the edges are sharp enough to worry you, cut some pneumatic hose down the length and put it over the edge. No more cuts.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 11-01-2017, 20:32
trusflan trusflan is offline
Trusflan
AKA: Sean Flanigan
FRC #0172 (Northern Force)
trusflan is an unknown quantity at this point
Do a google search for "sheet metal hemming". This method can be used to eliminate a sharp edge, but you do need a sheet metal brake to make it.
Unread 11-01-2017, 21:07
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Read the blue box that goes along with R06 .... It basically boils down what people like me (Humble Inspectors) think about your application of the thin edge. We may or may not think it's a hazard to the playing field and/or people in and around the field. You also may get a different interpretation of it's safety at each event you attend. It's best to not push the boundary of the rule too close in this case.
Ed Sparks
MECH TECH FRC-3959
Unread 11-01-2017, 21:37
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Another inspector here. The thing I usually do is to touch (gently) every edge and corner that I can get to easily. anywhere i think a student might try to lift the robot from or under the robot where you might try to find the screw you dropped. If there is any edge that makes me want to pull my hand back, then that edge needs something. often filing can do it, but for sheet metal it's often sufficient to use a strip of electrical tape the long way on the edge to soften it, sometimes a few layers. attaching split pneumatic tube (with zip ties if possible) is another option mentioned above that is ok. be careful splitting the tube the long way though. The safety inspectors are watching.
I also touch every zip tie i can find, even if clipped, they can often be sharp, so a careful clipping is often needed to prevent scratches.
