Go to Post You'll want to start with P, add some D to help prevent overshoot, and then add some I to help it get to the correct height if it isn't there from the P and D. - AustinSchuh [more]
Unread 11-01-2017, 20:08
1247Robotics 1247Robotics is offline
FRC #1247
1247Robotics is an unknown quantity at this point
Cost of Andymark 6" Mecanum Wheels
One of our mentors and just picked up a set of the Andymark 6" HD Mecanum wheels. The cost of the wheels is $104 each. We just re-read the rules on cost (R11 specifically) and we weren't sure if they are legal since they have to be used together as a set. that means their total cost is $416; which is over the $400 max. Please let us know if we can build our bot around these wheels.
Thanks!
Unread 11-01-2017, 20:09
FRC #1247
Re: Cost of Andymark 6" Mecanum Wheels
Here are the wheels in question:
http://www.andymark.com/product-p/am-0677.htm
http://www.andymark.com/product-p/am-0685.htm
Unread 11-01-2017, 20:14
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Just list their individual costs in your CAW. Each one is a COTS component.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 11-01-2017, 20:15
pmattin5459 pmattin5459 is offline
AKA: Patrick Mattin
FRC #5459 (Ipswich TIGERS)
Rookie Year: 2015
pmattin5459 is on a distinguished road
They are individual parts. So they can be used together. I would also consider the Vex wheels, as they're significantly cheaper and hold up well. We used them last year, and they worked pretty well (for mecanum wheels in a game that was not designed for them at all).
http://www.vexrobotics.com/mecanum-wheels.html
Unread 11-01-2017, 20:37
FRC #1247
Thanks for the info; and the suggestion on using vex in the future. In this case the mentor already purchased them.
Unread 12-01-2017, 00:33
SoccerTaco's Avatar
SoccerTaco SoccerTaco is offline
Mentor, Volunteer
AKA: Steve Parham
FRC #3824 (roHAWKtics)
SoccerTaco will become famous soon enough
The cost can be high - you'll be dropped from some team's pick lists...
Unread 12-01-2017, 01:54
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Originally Posted by SoccerTaco View Post
...you'll be dropped from some team's pick lists...
I assume you mean because of the mecanum and not because of high-cost items on a robot.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 12-01-2017, 02:00
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Exactly. If your team uses mecanum and cannot perform near a 2052 level of driver performance, then you will suffer the consequences. However, if your driver can perform well with mecanum, it can be a great advantage.
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 12-01-2017, 09:21
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
What year are you referring to?
GitHub
Unread 12-01-2017, 10:02
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Try ordering a set of 4, which is $399
http://www.andymark.com/product-p/am-0732.htm
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 12-01-2017, 10:12
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Ahh, let the Mecanum hate flow.
https://www.youtube.com/watch?v=_Avn2nT16FA
Unread 12-01-2017, 12:01
FRC #4607 (C.I.S.)
2013 and 2014 were the ones I have in mind. I don't remember 2015 - I have blocked that season from memory.
525 and 2052 are in this video here - zippy little buggers
Unread 12-01-2017, 12:13
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Doesn't look like they do a ton of strafing in those videos. I think they would've been equally or better served by running a tank drive. They are the best mecanum team in the world in my opinion, and the first year they don't use mecanum (2016) they make their first apprlearence to Einstein... coincidence? Possibly, but I think not.
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
Unread 12-01-2017, 12:29
wilsonmw04's Avatar
Coach
check when they are near the feeder station.
Unread 12-01-2017, 12:34
JesseK's Avatar
FRC #1885 (ILITE)
In the 2013 videos I saw, they saved maybe a second per cycle lining up to the HP feeder when compared to teams who had enough practice to realize they were misaligned and readjusted with tank.
I watched their 2014 videos over lunch today. It seems the biggest increase in agility they used to their advantage was to whip the robot around - going full reverse in a direction, doing a 180, and then continuing forwards in the original direction via a single, smooth maneuver. There were a few times they were pushed around the field, but at least at the Regional level it didn't hurt the overall match. They didn't directly strafe very much, but the increase in agility combined with smart driving and good strategy decisions seemed to help them win their Regionals.
At Worlds, however, particularly in the QF matches, they were definitely pushed around without question. The worst situations, due to the passing nature of that game, were when they went to pass to a partner and defense pushed them INTO that partner. In one case during QF's it was an effective open-field pin against 2 robots. Again, there was little strafing, but the increase in agility helped them bob-and weave in some cases. In the other cases, the defense that was played against them did the bobbing and weaving for them.
I don't mean this isn't an opportunity cost analysis, or what went wrong with 2052's 2014 season. There are obvious reasons to want Mecanum and to not want Mecanum drive, and 2052 seemed to use it pretty well. Versus non-aggressive defense, I think Mecanum will handle fine and can give the teams who have practice with it an edge. Yet on the World stage (which are what the high-profile guys above are alluding to), it will wind up being an exploitable weakness of an alliance.
GitHub
