Go to Post To my surprise, purple painted air tanks were illegal last year. AB - Andy Baker [more]
Unread 12-01-2017, 09:56
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Gears on the floor?
I wonder how many gears we'll see on the carpet? Dropped while loading or trying to place on the axles? Or getting knocked out of bots by hard impacts?
Will they get in the way? Cause robots to get high-centered?
Is it worthwhile to build a device to pick gears off the floor? This could save a lot of time running back & fourth across the field, but the design would be a major challenge, considering the new robot envelopes rule.
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
Unread 12-01-2017, 10:00
Billfred's Avatar
Billfred Billfred is offline
Re: Gears on the floor?
My own answers:
1) Double-digits per event.
2) Both.
3) Probably.
4) Only if they're at the chutes or right at the lifts, where they can jam against the wall.
5) Unlikely, given the bumper zone. But never say never.
6) Iron Kings labeled it Expert Mode on their priority list (something that we really want to pursue, but don't want to lock ourselves into if it severely compromises other functionality). I think others will make it happen too.
Unread 12-01-2017, 10:09
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by Billfred View Post
My own answers:
Same here. 3946 has this as a priority 2 item, which means about the same thing.
I expect dropped gears to be more common in quals than eliminations unless it's due to defense, e.g. "forced fumbles".
Unread 12-01-2017, 10:11
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
My own answers:
2) Both.
3) Probably.
Agreed with 1-5. 811 put a Prototype Team on it, and we think we have something that will work.
"It's NOT Just A Robot Thing!"
Unread 12-01-2017, 10:15
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Honest question:
Why bother? There are 22 gears available to each team (not counting the presets) and 13 places to put them. If a gear is on the ground, why make a mechanism to manipulate it when there are nine teammate-controlled extras?
Hi!
Unread 12-01-2017, 10:16
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
It would be my advice for anyone interested to possibly look back to 2013 for a bit of quick inspiration for floor intake designs.
Unread 12-01-2017, 10:17
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
We came to the conclusion that we don't need to pickup gears on the floor since there are plenty at the feeder station. You have 10 more gears than you need to get all 4 rotors going. (18 start + 3 preload + 1 in the airship = 22 gears) so even if you drop almost half of your available gears on the floor, you still have enough gears behind the wall to get your RP
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 12-01-2017, 10:18
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
The two questions I have for whether gears off the ground is a viable idea are:
A) How many gears do you imagine are going to be on the ground? and
B) Is your ground gear system faster than driving back to the load station?
461 Westside Boiler Invasion
45 Technokats
Originally Posted by Taylor View Post
Honest question:
Why bother?
There are many ways of accomplishing the same task. If you can pick up off the floor, then you have the capabilities of grabbing your opponents dropped gears as well, instead of trying to traverse the field for them.
Unread 12-01-2017, 10:19
Devlin Moody Devlin Moody is offline
FRC #1610 (B.O.T.)
Rookie Year: 2015
Devlin Moody is on a distinguished road
Honest question:
The only reason I can think of is in case it falls in a really awkward area and you're having trouble pushing it away, but I'm not too sure how often that would happen (if at all).
Unread 12-01-2017, 10:26
Billfred's Avatar
Honest question:
Because there may be a gear that isn't 50-60 feet away from me.
(Alternatively, because that might just be the fastest way to get control of one from the chute.)
Unread 12-01-2017, 10:31
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
I think this is the most strategically important reason to be able to pick them up. If an opponent fumbles a gear at their chute (maybe because of well timed defense) then you can grab it and take it right to your own lift.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 12-01-2017, 10:35
Unless the opponents tag you in their loading zone...
Unread 12-01-2017, 10:38
Robonut
AKA: Mr. Lam
Rookie Year: 2015
I'm picturing the opponent tries for a gear, drops it. Grabs another, takes off for their lift. You swoop in, kick it out of their loading zone, push it along the floor and finish intaking it outside the zone.
Unread 12-01-2017, 10:40
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Having an intake for floor gears is the only way to get a 120 point autonomous. That's maybe a decent reason to pursue it. Maybe.
http://www.angelbotics.com
Remember why you're doing this.
