Go to Post But before we jump to conclusions, I'll wait for kickoff and the manual. ;) - BrendanB [more]
Unread 11-01-2017, 14:19
Team2909 Team2909 is offline
FRC #2909
Team2909 is an unknown quantity at this point
Exclamation What kind of encoders should I get?
We have a toughbox micro and 6 inch mechanum wheels. What type of encoders do we need.
Unread 11-01-2017, 16:44
Re: What kind of encoders should I get?
Welcome to Chief Delphi !
http://youtu.be/LlSoEfAW47I?t=3m33s
Unread 11-01-2017, 16:59
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Incremental.
What are you trying to do? Theoretically you don't need encoders at all.
Unread 12-01-2017, 10:03
FRC #2909
We would like to put encoders on for autonomous. Originally had tank tracks, but we are switching to mechanum. Figured it would be easier and more reliable to use encoders.
Unread 12-01-2017, 10:12
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is online now
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Quadrature encoders are the standard for drivetrains.
Andymark has USDigital E4T encoders, which work well with their gearboxes. I have had bad experiences with their connectors though. They also sell SRX magnetic encoders, which we got this season. They require additional machining, but seem better in most other ways. Many teams also use Grayhill shaft encoders (you can find them on Digikey), but you will have to find someone else to talk about these.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 12-01-2017, 10:14
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
I've had success with the amt encoders from FIRST Choice.
461 Westside Boiler Invasion
45 Technokats
Unread 12-01-2017, 10:29
We would like to put encoders on for autonomous. Originally had tank tracks, but we are switching to mechanum (FTFY). Figured it would be easier and more reliable to use encoders.
Following up on asid61's question: What are you trying to do?
e.g. Do you plan to use the encoders just to close the loop on wheel speed?
or are you going to try to use the 4 encoder velocity readings to compute vehicle speed and yaw rate?
or are you going to try to use the 4 encoder position readings to compute vehicle position and angle?
or something else?
Unread 12-01-2017, 11:45
BDRessler's Avatar
BDRessler BDRessler is offline
Programming Lead
FRC #1828 (BoxerBots)
BDRessler has a spectacular aura aboutBDRessler has a spectacular aura about
we have had success with these in the past, but be careful with mecanum wheels, as they tend to sacrifice accuracy with encoders due to slippage. This year, we are looking into using an optical mouse for our linear odometry and an imu for rotational.
