Go to Post You could mount a small Black Hole on the top of your bot, and park it in front of the center goal - that would work...just keep your human player away from the event horizon. - KenWittlief [more]
  #46   Spotlight this post!
Unread 11-01-2017, 21:27
niklas674's Avatar
niklas674 niklas674 is offline
Mecanum+drive=A bad idea
FRC #0701 (Robovikes)
Team Role: CAD
Rookie Year: 2015
niklas674 is a glorious beacon of lightniklas674 is a glorious beacon of lightniklas674 is a glorious beacon of lightniklas674 is a glorious beacon of lightniklas674 is a glorious beacon of light
Re: Mecanum vs. Tank Drive?
Mecanums are great for an intake, past that I definitely would not recommend.
My views do not represent the views of my team
  #47   Spotlight this post!
Unread 11-01-2017, 21:34
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
As much of a fan as I am of using mecanum and not picking tank without proper game analysis, if you use pure mecanum this year you will have a bad time. From what I understand, you are not protected while placing gears, so all the fine adjustment in the world isn't going to help when you are being clobbered whenever you get close. If you can't do swerve, octocanum, nonadrive or butterfly drive, then you should stick with skid steer and focus on compensating for the less maneuverability.
  #48   Spotlight this post!
Unread 11-01-2017, 21:38
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Originally Posted by niklas674 View Post
While our best year involved us using a mecanum drive (mistake), we practically never used it in matches, the positioning was close enough that we didn't have to make large changes. Bottom line is that with plenty of drivers practice, you won't need to be able to strafe because your drivers will get to the exact spot almost every time.
__________________________________________________ ___________
TL;DR: Even in a game free of opponent pushing where mecanum was a viable option for strafing motion, it still was not our first choice in the design of the drive system. In the end it failed to work as well as we wanted.
I recall a few factors in 2015 in deciding to use mecanum. One was the fact that we were trying to be a landfill clearing robot, which required fine maneuverability due to the perpendicular orientation of the totes. We also constructed our robot to ride along the alliance wall behind the yellow totes as part of our autonomous, which required the strafing motion. But even with that in mind, we didn't even opt to use mecanum first.
Our first drive system iteration was an H drive with 4 omnis on the outside and one perpendicular omni in the middle. We wanted H drive over mecanum first, because we didn't want to bother with programming mecanum when H drive was a simpler option, and furthermore, H drive strafing is not as dependent on mass distribution as mecanum, if at all (as far as I know, correct me if I am wrong please). We knew that grabbing totes and making stacks at the forward area of the robot would drastically change the distribution, so H drive seemed to be the smarter option.
Unfortunately, the center wheel of our H drive would cause the robot to lose contact with some of the floor when driving up the scoring platform. At this point of failure in our prototyping, we settled for mecanum, and I say "settled" for a reason. Through all our days of practice and competition, the strafing abilities were hampered due to poor distribution of mass, especially with the addition of totes in a held stack. Because of this, our intial idea of a strafing wall-riding autonomous was given up for simpler options.
As Niklas mentioned, we barely strafed at all and drove the robot more like a tank, and I feel like we should have just designed for tank. After all, the only teams who were major scorers that beat us in all three of our regionals in finals did not have mecanum (118: 2 tread 2 omni tank, 254: 6 tread tank, 624: 5 omni H, 1678: 6 tread 2 omni tank) and two of them were the world champs, 1678 and 118, both of which we competed against at two separate competitions in the finals. I think I can chalk up our losses to these teams partly to a lack of proper control due to an improperly implemented mecanum drive.
The lesson I got from this was that even in a game where mecanum may seem like a good option due to the game design (no opponent pushing and lots of opportunity for fine control), it still might not be that great of a choice, so be careful with that decision. Some of the best teams use some form of tank drivein every game without fail, so I like to go their directions.
  #49   Spotlight this post!
Unread 11-01-2017, 21:53
ImMoMo's Avatar
ImMoMo ImMoMo is offline
AKA: Mo
FRC #2559 (Normality Zero)
ImMoMo is an unknown quantity at this point
Originally Posted by Caleb Sykes View Post
20fps is pretty fast, unless you have a shifter, consider choosing a slower top speed in order to get higher acceleration.
I agree, we've ordered two gearing options.. 15 ft/s and 20 ft/s... I don't think we'll be seeing 20 ft/s being super useful..
I do have a question, we're using a single reduction clamp gearbox overall 3.8:1 ratio, and the torque load seems to be about 2.8... while each CIM has a stall torque of 2.22--- I believe this is an issue... but also I'm not super familiar with stall torque... is it correlated to the torque load?
For the most part I agree with you.
One of the discussions we had while choosing our d-train was in regards to the precision required to place the gear.
I believe that butterfly or octanum would be ideal for this game, and it's relatively simple w/ COTS from VEX or very simple machining with a mill.
One of the counterpoints our students presented for defense was that, even if you have a tank drive and you're trying to place a gear, an opposing bot can knock you off of alignment as well. I think their reasoning to use mecanum wheels was to more easily avoid robots, and quickly align.
  #50   Spotlight this post!
Unread 11-01-2017, 21:56
ns3517's Avatar
ns3517 ns3517 is offline
FRC #0316 (Lunatecs)
ns3517 will become famous soon enough
I would say tank because the cons of mecanum out weigh the benefits
  #51   Spotlight this post!
Unread 11-01-2017, 22:21
sonichammer7476's Avatar
sonichammer7476 sonichammer7476 is offline
FRC #3959 (Morgan County Mech Tech)
Team Role: Scout
sonichammer7476 has a spectacular aura aboutsonichammer7476 has a spectacular aura aboutsonichammer7476 has a spectacular aura about
It all depends on what strategy you are going to go for of course, but if you are going to play any defense or fight for balls in the neutral zone, I highly recommend tank over mecanum. 99% of the time, you will get tossed around like a rag doll when facing non-mecanum robots. No traction. But as one user suggested earlier, if you are very familiar with mecanum and not familiar at all with tank, or your driver is skilled enough to handle the challenges of mecanums in this game, then go with mecanum. Otherwise, I say tank.
  #52   Spotlight this post!
Unread 11-01-2017, 22:48
chandrew's Avatar
chandrew chandrew is offline
Strategy Sun Tzu
AKA: Andrew Chan
FRC #1410 (The Kraken)
Team Role: Tactician
chandrew is an unknown quantity at this point
Originally Posted by Tom Ore View Post
We like mecanum wheels - if it's feels right for the game we'll use them. We have a total of 12 regional wins and 9 of the wins were with mecanum wheels.
+1
Our best regional year was 2014 with a mecanum
Andrew Chan
Dean's List Semi-Finalist 2016
  #53   Spotlight this post!
Unread 11-01-2017, 23:51
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
heh...our best regional year was 2009, with those hard plastic wheels.
Anecdotes aren't real helpful, some times.
  #54   Spotlight this post!
Unread 12-01-2017, 00:56
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp)
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
Originally Posted by Kevin Sevcik View Post
I'm curious if butterflies and octocanums collect alliance selection dings like straight mecanum. Or is it not relevant because teams willing/capable of these drives are usually pickers?
H drive and mecanum are treated worse than any other drivetrain (automatic DNP list most of the time). Buttterfly, octocanum and swerve are a little more complicated. Basically if I wasn't confident that they could fix it if it somehow broke, they would get lumped into the mecanum drive pile. If I was confident that the team could fix it if it broke, I would still put them below tank due to the inherent reliability issues but it would not completely prevent a team from being picked.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
1592 (2016-2017)
  #55   Spotlight this post!
Unread 12-01-2017, 08:37
MikePenn MikePenn is offline
FRC #6223 (Arsenal Engineering)
Rookie Year: 2016
MikePenn is an unknown quantity at this point
You could say last year was our best year with the plastic wheels
  #56   Spotlight this post!
Unread 12-01-2017, 11:10
chandrew's Avatar
Strategy Sun Tzu
AKA: Andrew Chan
I should clarify my post. The maneuverability of the mecanum drive allowed us significant advantages for alignment and evading defense, which allowed us to play at a higher level than we could have with a tank drive. The only issue we had with it was that the plastic rollers consistently liked to break off.
It likely is not the right drive train if you are trying to win Einstein, but it can perform very well at a regional level with good driver practice.
Andrew Chan
  #57   Spotlight this post!
Unread 12-01-2017, 11:23
BotDesigner's Avatar
BotDesigner BotDesigner is offline
Design/CAD/Strategy
AKA: David Gedney
FRC #4418 (Team Impulse)
BotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud of
2014 is considered one of the most defensive heavy games in FIRST history. If teams found a way to get them to work that year, I am sure you could find a way to get them to work well this year.
2016, 2017 Colorado FLL Champions
2014 FLL North American Invitational, 1st place Strategy and Innovation Award
2014, 2013 Kentucky FLL Champions
2nd place Strategy and Innovation Award
FLL Team Automaticus Rex, Team Captain('11-'14) youth mentor ('15-'17) FRC Team 4418 Member ('14-') Design Lead ('15-17')
  #58   Spotlight this post!
Unread 12-01-2017, 12:25
JohnFogarty's Avatar
AKA: @doctorfogarty
1102 who I've returned to working with this year used mechanum in 2014, seeded 3rd at their regional that year. The thing that held them back from winning their event that year was not their drive train I assure you.
I'm going to be doing some 6" 6WD 4 motor tank vs 6" 4 motor mechanum push tests this weekend. I hope I can bring back some useful information to settle this debate in some way.
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
  #59   Spotlight this post!
Unread 12-01-2017, 12:31
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Originally Posted by JohnFogarty View Post
Ill go ahead and say it. 1102 who I've returned to working with this year used mechanum in 2014, seeded 3rd at their regional that year. The thing that held them back from winning their event that year was not their drive train I assure you.
While your initiative is appreciated, and the results sure to be interesting, I think that sort of misses the point of mecanums.
Hi!
  #60   Spotlight this post!
Unread 12-01-2017, 12:34
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Explain what you mean by torque load and how you're determining it. Are you talking about the required torque to overcome the friction of the wheels?
