Go to Post Just the fact we were selected to compete in the eliminations energized the kids more than anything I had seen - Taylor [more]
Unread 12-01-2017, 10:41
BumblingBuilder's Avatar
BumblingBuilder BumblingBuilder is offline
Red is fast
AKA: Matthew
FRC #2169 (KING TeC)
BumblingBuilder will become famous soon enough
Re: Gears on the floor?
Also, ground intakes may have a quicker cycle time depending on the driver. If there's a gear on the floor outside of the loading station, the robot does not need to line up correctly with the chute. Instead it can, like a ball, just drive up to the gear laying on the floor. The time efficiency would range depending on drivers, but when you need 12 gears any time saving will help.
2014: FRC 2169 scouting/spirit, FTC 7897 Mechanical
2015: FRC 2169 Mechanical/CAD
2016: FRC 2169 Mechanical/CAD
2017: FRC 2169 Head of Mechanical
Unread 12-01-2017, 10:46
c.shu's Avatar
c.shu c.shu is offline
Alumni/Mechanical/CAD
AKA: Cole Shumaker
c.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to behold
Originally Posted by Kevin Thorp View Post
Will they get in the way?
Yes. Especially if there are many of them in one area.
Cause robots to get high-centered?
Yes. I foresee a large number of robots with low ground clearance this year.
Is it worthwhile to build a device to pick gears off the floor?
Yes. It is almost always worthwhile to have the option to pick up a game piece off the floor.
This could save a lot of time running back & fourth across the field, but the design would be a major challenge, considering the new robot envelopes rule.
Maybe. With a little creativity I think that the size restrictions can be worked around without too much complexity. You are only saving time if the floor pickup you design is faster than your cycle times. Don't bother picking up off of the floor if it is going to take you half the match to do it.
Unread 12-01-2017, 11:03
Originally Posted by GreyingJay View Post
I'm picturing the opponent tries for a gear, drops it. Grabs another, takes off for their lift. You swoop in, kick it out of their loading zone, push it along the floor and finish intaking it outside the zone.
I'm picturing lurking just out of sight behind the airship and swooping in to tag drivers who are preoccupied with the bait gear on the floor
Unread 12-01-2017, 12:46
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Gears on the floor could be an alliance strategy, where a great gear handler from the floor gets gears delivered to them by their partners. Of course, once they are on the ground, the opponents can play defense on them but they are harder to clear away than balls and they can only possess one at a time. Getting as many as possible to your side (even on the ground) and having a good pickup and placement mechanism would make it feasible for a single robot to place 12 gears if their partners were delivering them to the launchpad area.
I imagine you'd have 3 gears on robots and the reserve to start. At least one would be scored in auto and any left at the start of teleop would be dumped in the launchpad. Then all 3 robots would go for 3 more gears (and fuel). At that point, the gear handler would have 5 gears to place bringing the total to 7. Repeat this twice more (or 3x with 2 robots) and you'd be at 13.
Unread 12-01-2017, 14:07
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Keep in mind a good gear floor pickup greatly decreases travel time to acquire a gear and you need 12 for RP. it takes a while with across field vision to even obtain a gear. Would be much better to scoop fallen ones closer up. Plus greatly eases load time no line up needed human just drops gear on floor robot gets.... I think floor pickup of gears is a must due to cycle times for top gear bots considering driver station views, distance, defense and the rest. bots that just have passive gear collection will struggle IMO
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 12-01-2017, 14:47
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
FRC Design rule #4 you must be able to pickup your primary scoring object off of the floor.
Unread 12-01-2017, 14:56
NinjaMunkeeNao's Avatar
NinjaMunkeeNao NinjaMunkeeNao is offline
i'll literally do whatever :D
AKA: Naomi Christina Alexander
FRC #2395 (The Ninja Munkees)
Rookie Year: 2016
NinjaMunkeeNao is an unknown quantity at this point
I think having an intake would be great and it'd be helpful for sure. No gears would be wasted! Hard part is picking the gears off the floor and having time to score points everywhere else... I feel like going around picking up dropped gears would take a lot of time if there were a decent amount of them falling throughout the match... maybe that's just me though...
Unread 12-01-2017, 15:06
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
This is the real question.
Most of the designs I've seen so far on Twitter are a basically a funneled cup shape. Once the gear is in, it would take a pretty massive shakeup to drop it.
The two places where you're going to see dropped gears are at the receiving station, and at the lift. I'm not sure you'll see many dropped gears anywhere else.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 12-01-2017, 15:31
Rookie Year: 2016
That's true. The amount's definitely important. Spend time making an intake and gears are rarely dropped on the floor... that wouldn't be good.
Unread 12-01-2017, 17:02
Decent floor pickup and your Human Player to drop gears on floor rather than robot having to line up and waste time , so there will be as many gears on the floor as you need you never have to waste time with a line up..its the way to go. Too many gears too little time. More engineering sure, worth it yes.
Unread 12-01-2017, 17:07
AdamHeard's Avatar
Lead Mentor
Better take back that division win from 1503 in 2011, and a good deal of division and championships wins from teams in 2006.
Unread 12-01-2017, 17:11
Chris is me's Avatar
AKA: Pinecone
Plus more than half of Einstein 2013...
Unread 12-01-2017, 17:17
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
I don't uderstand the love for picking up gears off the floor in this thread. Unless you have an amazing floor pickup picking up gears from the floor still takes time, maybe less than if you were loading from a loading station but time none the less. I wouldn't be surprised if a well practiced gear scorer was able to to go to the loading station, grab a gear and score it before an average robot could score one picked off the ground next to the airship.
In 2013 two of the world champions had intakes during regional play and removed them for championship even though they were necessary for a fairly common high scoring auton. It's not like ground intakes were undervalued that year either considering there were ultra competitive teams who only had the option of picking up from the ground (2056 notably)
2016: FRC 865 Mentor
Unread 12-01-2017, 17:31
TroyCDH's Avatar
TroyCDH TroyCDH is offline
FRC #2450 (Radierbots)
TroyCDH is on a distinguished road
2450 did some CAD modeling to pick up the gear. I wish the gear had a large chamfer to get a "dustpan" under it while laying flat. Fairly sharp corner on carpet that probably cant be scooped up.
Ideas welcomed.
Unread 12-01-2017, 17:37
I think you might be underestimating Vision and defense..... going to exact same spot is of course a tendency and you can be if you are very effective at gear collection that tendency will be used against you and slow you down a lot when you need 6...at least with floor the pickup point will be different and you could have several gears laying on floor pretty sure you can chuck the gears out at a high rate forcing them away from the retrieval area and being more unpredictable in picking them up
Only downside (with scoops) I see to floor pickup is trying to no get messed up with balls which will be prevalent
