Go to Post if we can't rely on experience and the human mind from time to time, then we're in trouble, aren't we? - Adam McLeod [more]
Unread 12-01-2017, 16:16
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
prototyping speed controller
What do you use for an off bot prototyping speed controller?
Something you can just hook up to a battery and motor and manually adjust speed.
Thanks
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 12-01-2017, 16:20
Breakaway3937's Avatar
Breakaway3937 Breakaway3937 is offline
Director
AKA: Brian "Robo" Jones
FRC #3937 (Breakaway)
Breakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really nice
Re: prototyping speed controller
I took an old drill of ours, and we wired it to hook up to a battery and the other end to an Anderson connector for our motors. The drill has a variable switch, so we can adjust the speed of the motor and safely hook up a battery. It cost us nothing since we had all the parts around the shop and the drill bit the dust last year.
"There is no luck. It is only when preparation meets opportunity."
Unread 12-01-2017, 16:43
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I just bought a couple of these from Amazon. Looks like they are non revering though.
We also use surplus jags (are there any other kind) with a andymark thrifty throttle. The Jags have the advantage of having a 5 volt output to power the thrifty throttle.
Unread 12-01-2017, 17:11
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
We traditionally have used Talon SRs with an Arduino giving PWM, but we may switch to SPARKS since those will be our motor controller for the bot. (and we put fans on all of our Talons, and we'd rather not deal with those)
Unread 12-01-2017, 17:27
When you get these and have a chance to try them, would you please post your findings?
e.g. What is the resolution of the potentiometer (step size of change in output voltage)
and
How stable is the output voltage?
Stuff like that.
Thanks.
[EDIT] OBTW, I like this one better. It has 4 "power tubes" !! ... Reminds me of my youth :-)
Name:	4 power tubes.png
Unread 12-01-2017, 20:14
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
I recently made a tiny box that contained two talon sr's and used an arduino to provide pwm input. Used a potentiometer and a flip button to control the speed and direction of the output.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
