Go to Post Like a wizard, Car Nack is never late. He always arrives precisely when he meets you. - EricH [more]
Unread 12-01-2017, 14:06
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Realistic high goal scoring rate
Originally Posted by Chris is me View Post
This isn't 2016 - volume and accuracy are tradeoffs where the right answer very well may be on the side of volume. Turreted shooter in 2009 could be more accurate than dumpers, but dumpers certainly were the more dominant design in general that year. This year's game has five times as many game pieces as 2009!
I am in complete agreement with this, actually. The important shooter metric is balls scored per second, not accuracy or balls fired per second. Erring on the side of volume is almost certainly preferred because it's probably easier to increase accuracy for a high volume system than to increase volume for a high accuracy system. I think it IS interesting that if you're pursuing a single stream shooter*, at some point you have to start backing away from the goal to increase your rate of fire without running balls into each other.
*How long do you think until the first joke about crossing the streams?
I don't think that's how it works. The motor is only at max power spinning half its free speed at full voltage, IE if the load the motor is under is slowing it down that much. If you're just spinning the motor at half its free speed with speed control, you're just applying a bit more than 6 volts to the motor (a bit more to account for friction losses etc). You definitely do want to be spinning a flywheel at less than 100% speed so it has some headroom to recover with, but I don't think it's exactly half voltage or half free speed either.
Like I said, I need to revisit my spreadsheet to better account for this. But two things are true about my statement:
1. If your wheel slows down by x% per ball, the fastest way to spin it back up to target speed is at at the peak mechanical power point. (Physics, that) And the peak power is at 12V and 50% free speed.
2. Peak power is the MOST power you'll ever get out of the motor. That's 337W for a single CIM. If it takes 33J to fire a ball, the most balls you can fire without slowing down is 10 balls per second. And that's going to be with the motor running at 1/2 free speed. If the motor's running any faster, it won't put enough energy back into the system and the wheel will slow until energy out = energy in.
Unread 12-01-2017, 14:13
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Unread 12-01-2017, 14:28
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Originally Posted by notmattlythgoe View Post
Ghostbusters!
14:06-14:13, so ~7 minutes
Longer than I expected actually.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 12-01-2017, 14:40
He has to have some kind of intelligent filter that notifies him of joke opportunities, I swear.
Unread 12-01-2017, 14:48
Joining the 900 Meme Team
FRC #0079
That's the first time I've ever heard him referred to as "intelligent"
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant future
We are looking at about 12 balls per second at the moment with our protoype with consistency.
Team member 2004-2008
Team mentor 2008-20XX
http://www.team1708.com/
"Education is a powerful tool. Always use it to better someone else's life"
Andrew_L's Avatar
Andrew_L Andrew_L is offline
#DriveSwerveEveryDay
AKA: Drübr Inc.
FRC #1323 (Madtown Robotics) #971 (Spartan Robotics)
Andrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant future
97.1 balls per second.
Unread 12-01-2017, 15:11
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
next thing you know 254 does better than that
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 12-01-2017, 16:03
rick.oliver's Avatar
rick.oliver rick.oliver is offline
Mentor - Retired
AKA: Pap
rick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond repute
So, check my math, but assuming a single Fuel leaving the shooter wheel which is located at the top of a tall robot parked in the key against the boiler wall. My trajectory model calculates about 86 degree launch angle at about 5.7 m/s muzzle velocity. At a 5" pitch, that is 40 to 45 Fuels per second.
So that would be the max; of course, there would be a gap as you wouldn't be feeding the shooter as fast, so something less than that.
Am I missing something?
Unread 12-01-2017, 16:17
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Does that include drag on the wiffleball?
___________________
- Tennyson, Ulysses
Unread 12-01-2017, 16:29
s-neff's Avatar
s-neff s-neff is offline
AKA: Sam
FRC #0841 (Biomechs)
s-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud of
Without checking your math, that seems like a solid upper limit "in flight". The feed process into the shooter will definitely be the limiting factor for top teams.
Fun:
Mentor - Team 841 (2015 - ? )
Mentor - Team 4 (2013 - 2014)
Student - Team 192 (2009 - 2010)
Work:
SunPower Systems, Product Engineering - Utility Power Plants (2015 - ? )
BSci, Mechanical Engineering, UCLA (2010-2015)
Unread 12-01-2017, 17:03
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Peak rate or sustained rate? I could see some team with peak rates well above 30 balls/second.
Flywheel shooters are the only way to launch a ball
Unread 12-01-2017, 18:49
How fast is the ball traveling at the apex of your trajectory? The slowest speed on your trajectory is what you should use with pitch to calculate balls per second.
Unread 12-01-2017, 19:20
Andrew_L's Avatar
AKA: Drübr Inc.
I can't hear you over my ACTUAL TRANSFORMER ROBOT*
*Whose design I didn't contribute to in the slightest
Unread 12-01-2017, 19:58
At 25 ft/s, that's about 12 lbs of thrust. I don't think you'll be going to space today with that engine.
