Go to Post Meh, that's nothing a freshman with a drill press and a dremel can't fix... - Chad987 [more]
Unread 12-01-2017, 16:35
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Drum shooter?
Nothing wrong with a drum to process balls. But they're much smaller than the 2009 balls. So there is a risk or jamming, or having a very narrow helix.
Trick is getting them to a high speed shooter.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 12-01-2017, 16:48
viggy96 viggy96 is offline
FRC #3331
viggy96 is infamous around these partsviggy96 is infamous around these parts
Re: Drum shooter?
I guess my original question wasn't clear. I was thinking about using a drum as the high speed shooter, in order to be able to shoot multiple balls at once, rather than a single wheel, which can only shoot one ball at a time.
Unread 12-01-2017, 16:49
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Drum shooter?
Drum could work .
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 12-01-2017, 18:02
SenorZ's Avatar
Physics Teacher
AKA: Tom Zook
Re: Drum shooter?
I'd love to see a continuous stream of balls flying out of a drum!
Consider the power consumption. The balls are pretty light, but trying to pull several up from the bottom of your hopper with enough speed to propel them 5+ feet in the air, all using the same mechanism is going to be challenging.
Unread 12-01-2017, 18:13
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: Drum shooter?
I might be wrong, but I still think you're misunderstanding the OP's intentions. I think the OP is asking about just using a large, wide flywheel capable of launching more than one ball at a time, not using the drum that contains the Fuel to also launch it.
Unread 12-01-2017, 19:50
FRC #3331
Re: Drum shooter?
I was more thinking along the lines of having a drum after the loading conveyor. The conveyor would be low speed used for loading the hopper and transporting the balls up to the high speed shooting drum.
Unread 12-01-2017, 20:18
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Drum shooter?
Okay, 74g ball. Call it 8 m/s muzzle velocity. Let's assume rolling without slipping out of the shooter, we'll call it a ring so I don't have to look up inertia of a wiffle ball. So 1/2mv^2+1/2mr^2(v/r)^2. So r cancels and mv^2. Each shot has about 5j. Yes inefficiencies and all that. Say 10% efficiency, so 50j per shot. A properly geared CIM would put out 334W, so 6.5 shots per second without slowing. So with those assumptions, a 2 CIM drum shooter could put out 13 shots per second without slowing.
Unread 13-01-2017, 10:33
pipsqueaker pipsqueaker is offline
FRC #1124
pipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to all
Re: Drum shooter?
Drum shooter is absolutely the way to go (unless anyone can design a high-capacity catapult, 1678?)
Unread 13-01-2017, 11:05
rick.oliver's Avatar
rick.oliver rick.oliver is offline
Mentor - Retired
AKA: Pap
rick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond repute
Re: Drum shooter?
I agree, a drum, roller, wide wheel, what ever you call it that accepts and discharges multiple balls should work. There will be a trade off between accuracy and width. So, 2, maybe three wide is about the limit is my guess.
Unread 13-01-2017, 11:22
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Re: Drum shooter?
I for one would love to see a robot that launches the entire contents of their hopper with one shot of a catapult.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 13-01-2017, 11:54
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Drum shooter?
Drum/roller shooters work pretty okay I guess...
Especially when coupled with a constantly-recycling hopper.
Unread 13-01-2017, 12:10
RoboChair's Avatar
AKA: Devin Castellucci
Re: Drum shooter?
You leave us out of this! Just because I am well versed in catapults does not mean we can build any catapult.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 13-01-2017, 20:52
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
Re: Drum shooter?
That math works out but we have to think of things in terms of instantaneous vs average ROF. Back in the bad old days of paintball before the more sophisticated hoppers and good, high flow regulators we would run into this all the time. Your math would run very similarly to what you just did. You then try and implement that solution and you have problems of inconsistent shots or misfeeding. Then you would realize that you only have so much control over your ROF. Very rarely would you be able to get the feeding so that each shot is evenly spaced in time. If your goal is to be able to handle a real world 13 fps average over a load of fuel, you need to be able to push quite a bit more than the theoretical numbers for 13 per second. The reasoning is while your average may be 13 per second over 2-5 seconds, you may see spacings between fuel characteristic of much faster rates of fires. Say, the first 3 might be actually 1/20th of a second between the fuel while the last 3 might be 1/6th of a second between shots because the system feeding the shooter loses efficiency when the hopper gets low.
What I just said starts to fall apart if you have a completely linear indexing system for the fuel where it will not have to go from bulk storage to single file. This means we can index the feeding uniformly throughout the firing cycle. Unfortunately for us, this will reduce the number of fuel a robot can carry per unit volume which is not good for cycle efficiency.
