Go to Post Brandon, it's not an issue... but the fortune cookie thing that you get when you give someone rep is a little creepy... - Beth Sweet [more]
Unread 12-01-2017, 18:11
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Drum shooter?
Originally Posted by viggy96 View Post
Does anyone here think it would be reasonable to shoot balls using a spinning drum, rather than a wheel, so that you could shoot 2 or 3 wide?
The Fuel is 5" wide. The opening 17.5-21.5" wide depending upon how you look at it.
IMHO, you will be challenged to get a 2 wide stream into the opening.
Unread 12-01-2017, 18:13
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Drum shooter?
Opening can be wider 28" - 24" with shorter 2' bot feeding easy 4 or 5 across also same for shooter
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 12-01-2017, 18:15
AdamHeard's Avatar
Lead Mentor
Re: Drum shooter?
He's talking about the goal dimensions, which doesn't change with robot size.
Also not sure how you get a 24" opening on any legal robot.
Unread 12-01-2017, 18:17
Re: Drum shooter?
Hey Adam ,
Max volume X,Y is 40X36 6" bumper x2 (-12) = 24 or 28 in theory with a custom drive base, if that's a good idea another story.
I was thinking intake now that I re-read that again
Unread 12-01-2017, 18:21
AdamHeard's Avatar
Lead Mentor
Re: Drum shooter?
Hey Adam ,
You're forgetting the width of the bumper segments on each side at ~3.25" each.
Unread 12-01-2017, 18:43
RoboChair's Avatar
AKA: Devin Castellucci
Re: Drum shooter?
Yes, Drum Shooter.
12 Years and counting! Over a third of my life has been spent with FRC.
