Go to Post If mecanum wheels are the answer, I have found that I have asked myself the wrong question. - jwfoss [more]
Unread 12-01-2017, 16:28
viggy96 viggy96 is offline
FRC #3331
viggy96 is infamous around these partsviggy96 is infamous around these parts
Drum shooter?
Does anyone here think it would be reasonable to shoot balls using a spinning drum, rather than a wheel, so that you could shoot 2 or 3 wide?
Our current plan is more or less inspired by 148's 2009 bot, Tornado, (though without the fancy ball storage) (https://www.youtube.com/watch?v=aCVLZFyEI1Y) and we were trying to see if we could put a shooter on it as well, to shoot for the high goal. Being able to empty the hopper faster would be very beneficial.
Unread 12-01-2017, 16:35
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Drum shooter?
Nothing wrong with a drum to process balls. But they're much smaller than the 2009 balls. So there is a risk or jamming, or having a very narrow helix.
Trick is getting them to a high speed shooter.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 12-01-2017, 16:48
FRC #3331
Re: Drum shooter?
I guess my original question wasn't clear. I was thinking about using a drum as the high speed shooter, in order to be able to shoot multiple balls at once, rather than a single wheel, which can only shoot one ball at a time.
Unread 12-01-2017, 16:49
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Drum shooter?
Drum could work .
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 12-01-2017, 18:02
SenorZ's Avatar
Physics Teacher
AKA: Tom Zook
Re: Drum shooter?
I'd love to see a continuous stream of balls flying out of a drum!
Consider the power consumption. The balls are pretty light, but trying to pull several up from the bottom of your hopper with enough speed to propel them 5+ feet in the air, all using the same mechanism is going to be challenging.
Unread 12-01-2017, 18:11
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Drum shooter?
The Fuel is 5" wide. The opening 17.5-21.5" wide depending upon how you look at it.
IMHO, you will be challenged to get a 2 wide stream into the opening.
Unread 12-01-2017, 18:13
Re: Drum shooter?
Opening can be wider 28" - 24" with shorter 2' bot feeding easy 4 or 5 across also same for shooter
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: Drum shooter?
I might be wrong, but I still think you're misunderstanding the OP's intentions. I think the OP is asking about just using a large, wide flywheel capable of launching more than one ball at a time, not using the drum that contains the Fuel to also launch it.
Unread 12-01-2017, 18:15
AdamHeard's Avatar
Lead Mentor
Re: Drum shooter?
He's talking about the goal dimensions, which doesn't change with robot size.
Also not sure how you get a 24" opening on any legal robot.
Unread 12-01-2017, 18:17
Re: Drum shooter?
Hey Adam ,
Max volume X,Y is 40X36 6" bumper x2 (-12) = 24 or 28 in theory with a custom drive base, if that's a good idea another story.
I was thinking intake now that I re-read that again
Unread 12-01-2017, 18:21
AdamHeard's Avatar
Lead Mentor
Re: Drum shooter?
Hey Adam ,
You're forgetting the width of the bumper segments on each side at ~3.25" each.
Unread 12-01-2017, 18:43
RoboChair's Avatar
AKA: Devin Castellucci
Re: Drum shooter?
Yes, Drum Shooter.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 12-01-2017, 19:50
FRC #3331
Re: Drum shooter?
I was more thinking along the lines of having a drum after the loading conveyor. The conveyor would be low speed used for loading the hopper and transporting the balls up to the high speed shooting drum.
Unread 12-01-2017, 20:18
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Drum shooter?
Okay, 74g ball. Call it 8 m/s muzzle velocity. Let's assume rolling without slipping out of the shooter, we'll call it a ring so I don't have to look up inertia of a wiffle ball. So 1/2mv^2+1/2mr^2(v/r)^2. So r cancels and mv^2. Each shot has about 5j. Yes inefficiencies and all that. Say 10% efficiency, so 50j per shot. A properly geared CIM would put out 334W, so 6.5 shots per second without slowing. So with those assumptions, a 2 CIM drum shooter could put out 13 shots per second without slowing.
Unread 13-01-2017, 10:33
pipsqueaker pipsqueaker is offline
FRC #1124
pipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to all
Re: Drum shooter?
Drum shooter is absolutely the way to go (unless anyone can design a high-capacity catapult, 1678?)
