Go to Post One day the code will be written first, and then a robot built around it - dag0620 [more]
Unread 12-01-2017, 20:47
ahudson ahudson is offline
FRC #3179
ahudson is infamous around these parts
Re: Connector on Andymark Hall Effect Sensor
Originally Posted by B95 View Post
My team was in the progress of putting together a drivetrain using the Andymark swerve modules (am-3009) and were faced with the same problem, as the modules use hall effect sensors on the steering motors. We wanted to connect them directly to the TalonSRX's just as you do, and we ended up just using breakout boards; I'm guessing we could not find any of the cables you are looking for.
Can you post a photo of your wiring for the complete set up?
