Go to Post FIRST Championships event is not about winning, its about the experience, the atmosphere, the people and the sites, there are a lot of amazing things to see at The Championships. - Mike Schroeder [more]
Unread 03-01-2017, 19:23
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Connector on Andymark Hall Effect Sensor
Can anyone tell me if I can buy a connector for
http://www.andymark.com/product-p/am-2816a.htm
Specifically, one that I can attach ribbon cable to in order to have a direct line from this motor to the TalonSRX
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 03-01-2017, 20:04
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: Connector on Andymark Hall Effect Sensor
Link directly here for your cable: http://www.andymark.com/product-p/am-2993.htm
You'll have to get a SRX cable, chop the end off and correctly solder in the above cable to work with a SRX.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 03-01-2017, 20:43
ArchdukeTim
That's not what I want.
I want to not solder. I have breakout boards so I'd rather solder to that, but if I can find an IDC connector then I can just snap in a cable and be good
Unread 04-01-2017, 21:20
B95's Avatar
B95 B95 is offline
FRC #0103 (Cybersonics)
Team Role: CAD
Rookie Year: 2015
B95 is an unknown quantity at this point
My team was in the progress of putting together a drivetrain using the Andymark swerve modules (am-3009) and were faced with the same problem, as the modules use hall effect sensors on the steering motors. We wanted to connect them directly to the TalonSRX's just as you do, and we ended up just using breakout boards; I'm guessing we could not find any of the cables you are looking for.
Unread 04-01-2017, 22:36
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
if you get the above noted cable cut the power pole connectors off and solder to breakout board you would be done
Unread 12-01-2017, 20:47
ahudson ahudson is offline
FRC #3179
ahudson is infamous around these parts
Can you post a photo of your wiring for the complete set up?
Unread 14-01-2017, 10:47
frodobaggins05's Avatar
frodobaggins05 frodobaggins05 is offline
AKA: Wiring Specialist
FRC #2783
Team Role: Electrical
Rookie Year: 2016
frodobaggins05 is infamous around these partsfrodobaggins05 is infamous around these partsfrodobaggins05 is infamous around these parts
Trust me You're definitely going to need to custom make the connector
Unread 14-01-2017, 10:49
FRC #2783
Rookie Year: 2016
Are you just not good at soldering, or do you not want to?
