Go to Post And then the judges joined in and did the wave! - Basel A [more]
Unread 12-01-2017, 18:38
Oromus's Avatar
Oromus Oromus is offline
Lead Programmer, Community Liaison
AKA: Ryan
FRC #1902 (Exploding Bacon)
Oromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to behold
USBCamera setExposure() not working
Heya. I've been trying to use the USBCamera class' setExposureManual() function (apologies for the slight title type) to lower the exposure of our Microsoft Cinema webcam. The problem I'm having is pretty straightforward; no matter what values I pass it, the exposure doesn't change. The default exposure is way too bright, and it whitewashes almost every light source/bright surface to the point where the it is entirely white. Has anyone else experienced this, and what have you done to fix it? If you've gotten exposure control working with the Microsoft Lifecam 3000, please share that and what workarounds/fixes you had to apply (if any). We were using the Lifecam last season but encountered the same problem.
2016 Roles: Manipulator, Strategy Co-Lead, Programmer
2016 Orlando Regional: Quarterfinalist (Captain w/ 1557, 5557 and 4352)
2016 Rocket City Regional: Quarterfinalist (w/ 283 and 34), Regional Chairman's Award Winner
2016 Championship: N/A (had fun and was inspired, that's what counts)
2015 Role: Programmer
2015 GSCR: Quarterfinalist (w/ 4189 and 4026), Regional Chairman's Award Winner
2015 Orlando Regional: Semifinalist (w/ 456 and 86), Imagery Award Winner
2015 Championship: Pit Safety Award Winner
Unread 12-01-2017, 19:12
sanghakchun sanghakchun is offline
AKA: Andy
FRC #0846 (The Funky Monkeys)
Rookie Year: 2015
sanghakchun is an unknown quantity at this point
Re: USBCamera setExposure() not working
Our team used the
v4l2-ctl
command line utility on the roboRIO to control our exposure (and auto-focus) settings on the Lifecam. We had a script that would run it with a set of arguments on every boot, as it wasn't persistent.
I can't remember the specific arguments we used, however, so you'll need to play around a bit with the utility to find the property you need to set
Unread 12-01-2017, 19:22
Oromus's Avatar
AKA: Ryan
Originally Posted by sanghakchun View Post
Our team used the
v4l2-ctl
I was about to start looking into that, good to hear it works! How did you guys install it onto your roboRIO? Did you cross compile .so files, or...? If you can, can you provide/link the .so files you built/used/installed? Thanks!
Unread 12-01-2017, 21:13
AKA: Andy
Rookie Year: 2015
No need to compile anything! The binary is already on the roboRIO
One thing to note: In our experiments, either v4l2 or the Lifecam seemed to implement poor exposure control; we were only able to set it to one of the extremes (super high or super low). Thankfully, the super low exposure was able to pick up the retroreflective tape well, and so there was no need to use an exposure in the middle.
Unread 12-01-2017, 23:44
BenBernard BenBernard is offline
FRC #5687 (The Outliers)
Rookie Year: 2015
BenBernard is on a distinguished road
With our Lifecam 3000 connected to our Pi last year we used:
v4l2-ctl --set-ctrl=exposure_auto=1
v4l2-ctl --set-ctrl=exposure_absolute=25
This year we're finding that mechanical exposure control* is a lot more reliable and less fussy.
*Sunglasses. Seriously, not everything is a software problem!
Unread 13-01-2017, 09:41
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
This may seem trivial, but are you using the range the function takes (0-100)?
I would have said try NIVision because that's how we did exposure control last year (not lifecam), but of course it's not in WPILib anymore
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 13-01-2017, 21:34
Justin Buist Justin Buist is offline
FRC #4003 (TriSonics)
Rookie Year: 2015
Justin Buist is an unknown quantity at this point
Using the documented range is probably a bad idea. We dorked around with the Lifecam last year and found out, and don't quote me on the numbers, the camera actually supported exposure ranges from -11 to 2.
