Re: Wiring a router without a VRM
I personally wouldn't risk it - both sources are 12V, but the VRM is limited to 2A, whereas the PDP outputs are 20A or higher. More importantly the VRM is a regulated 12V source, whereas the PDP outputs provide a variable battery voltage. You probably wouldn't be at risk of frying it, but it would likely reboot if your battery voltage dropped for a moment. |
Sorry I should have clarified, I didn't want to use it during competition just for a few tests. Thank you for the responses I think I'll play it safe and see if I can get it arranged to get another VRM so I don't break anything
This is safe, for a testbed in a pinch.
Replace the 10A VRM Fuse on the PDP with a 2A fuse and use the VRM power plugs on the PDP to power your radio. Last edited by Fusion_Clint : 12-01-2017 at 23:20. |
Or perhaps you could use one of these https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It's an adjustable buck/boost voltage regulator that you can set to 12 V output at 25W (a smidge over 2A). I have one and it does a good job. |
Until teams receive the correct wiring to supply VRM power to their radios, you should be able to power them via ethernet (PoE) from the RoboRio.
The roboRIO doesn't provide POE. That would require a power injector (powered from a VRM or similar buck boost supply). |
#7
Huh, I was told our by our FTA that the local teams got their robots running at Quick Build via PoE. I'll have to clarify how that worked.
#8
As a test robot, you can put a 2nd battery that only powers the radio. that would avoid brownout problems. If the robot is not moving, then you can plug the radio into an AC power supply. Or, battery->dc to ac converter -> 110v to 12v dc power supply -> radio
#9
If your radio pulls more than 2 amps, it is already broken. The extra ampacity of the PDB just lets the broken radio smoke a little more. The big issue is brown outs will reset the radio. For limited testing I wouldn't have any issues. You can always put an in line fast blow fuse,
#10
Here's an example: |
#11
We're looking into doing this, I ended up ordering some boost converters, but if I don't need them then I'm not going to use them. |
#12
Note: This is only for the older OM5P-AN radio. The New OM5P-AC is looking for 24v on the Passive POE port. POE Input:12-24v in the port closest to the barrel input. The 802 port wants 48v Last edited by Mark McLeod : 13-01-2017 at 10:09. |
#13
If you're just using it for testing I advise you just use an ethernet cable. It's much easier than all the work of setting up a bridge
