Go to Post We were all rookies once, and we really have two ways to go about things: either take a page from the powerhouses and emulate their style, or complain about not having anything and risk falling into oblivion. - George A. [more]
Unread 12-01-2017, 21:22
TheBakerMan TheBakerMan is offline
AKA: Baker Poling
FRC #4283 (INSPIRE)
Rookie Year: 2015
TheBakerMan is an unknown quantity at this point
Wiring a router without a VRM
Our team has while working on the competition robot had the Kit of Parts drive train running as a test bot for the programmers. Our lead programmer wanted me to connect a router so he didn't have to deal with an Ethernet cable constantly connected anymore but when I went to do this I realized that we don't have a spare VRM to connect the router to the PDP with. So the question is do I have to use a VRM to power the router or is there another way to go about this?
Unread 12-01-2017, 21:33
arichman1257's Avatar
arichman1257 arichman1257 is offline
VP, Control Systems Captain, Coach
AKA: Alan Richman
FRC #1257 (Parallel Universe)
Team Role: Electrical
arichman1257 will become famous soon enougharichman1257 will become famous soon enough
Re: Wiring a router without a VRM
R51: The Wireless Bridge power must be supplied directly by the 12V 2A output of a CTR Electronics
Voltage Regulator Module (VRM) (P/N: am-2857, 217-4245) and must be the only load
connected to those terminals.
TL;DR you have to use the VRM
But I presume that you are not looking for competition legal. Still, every other power output terminal on the PDP is 10A, 20A, 30A, or 40A max so if there was to be an issue your radio could be destroyed.
Still TL;DR bad idea
1257 Parallel Universe: 2014 - 2017 Seasons
2017: Vice President, Control Systems Captain, Drive Coach
2016: Control Systems Captain, Operator. MAR District Championship Winner, MAR Mt. Olive Event Winner, MAR Bridgewater-Raritan Event Finalist
2015: Control Systems, Operator. MAR North Brunswick Event Finalist
2014: Programming/Electronics Apprentice. MAR Clifton Event Winner
Last edited by arichman1257 : 12-01-2017 at 21:37. Reason: Realized that you probably aren't looking for the competition legal answer.
Unread 12-01-2017, 21:40
JR0405's Avatar
JR0405 JR0405 is offline
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
Yes, you need one for competition as stated above but I'm assuming you mean at the moment until you get a new one. As obvious by the fact that the PDP directs power straight from the battery, the PDP does not supply a constant 12V which is why the voltage regulator module is necessary. For know I would think that it'd be ok to connect it to any 12V output of the PDP. The radio can handle up to 24V and if there isn't enough power it will just shut off which unlike in a match isn't terribly important.
TL;DR I'd assume it's ok to connect it to one of the 12V outputs of the PDP the radio could shut off if the power drops to low for testing
#StaySavage
Unread 12-01-2017, 21:44
jSchnitz's Avatar
jSchnitz jSchnitz is offline
Lead Programmer, Operator
AKA: Jacob Schnitzlein
FRC #1986 (Team Titanium)
jSchnitz is on a distinguished road
I read the OP as asking if it's possible / safe to run the radio from a PDP WAGO output instead of the VRM in a pinch, not if it's competition legal.
I personally wouldn't risk it - both sources are 12V, but the VRM is limited to 2A, whereas the PDP outputs are 20A or higher. More importantly the VRM is a regulated 12V source, whereas the PDP outputs provide a variable battery voltage. You probably wouldn't be at risk of frying it, but it would likely reboot if your battery voltage dropped for a moment.
2016: Kansas City: Winner, Industrial Design Award. Smoky Mountains: Finalist, Engineering Inspiration Award. Archimedes Division: Winner, Industrial Design Award. FRC Dean's List Finalist
2015: Arkansas: Finalist, Quality Award. St. Louis: Winner, Industrial Design Award. Queen City: Winner, Quality Award. Carver Division: Quarterfinalist. FTC Dean's List Finalist
2014: Central Illinois: Winner, Chairman's Award. Kansas City: Winner, Innovation in Control Award. Newton Division: Semifinalist, Industrial Design Award.
Unread 12-01-2017, 22:11
AKA: Baker Poling
FRC #4283 (INSPIRE)
Rookie Year: 2015
Sorry I should have clarified, I didn't want to use it during competition just for a few tests. Thank you for the responses I think I'll play it safe and see if I can get it arranged to get another VRM so I don't break anything
Unread 12-01-2017, 23:18
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
This is safe, for a testbed in a pinch.
Replace the 10A VRM Fuse on the PDP with a 2A fuse and use the VRM power plugs on the PDP to power your radio.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Or perhaps you could use one of these https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It's an adjustable buck/boost voltage regulator that you can set to 12 V output at 25W (a smidge over 2A). I have one and it does a good job.
Unread 12-01-2017, 23:46
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
Until teams receive the correct wiring to supply VRM power to their radios, you should be able to power them via ethernet (PoE) from the RoboRio.
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 12-01-2017, 23:51
Um, no.
The roboRIO doesn't provide POE. That would require a power injector (powered from a VRM or similar buck boost supply).
Unread 13-01-2017, 01:12
AKA: Josh Patterson
Originally Posted by Mark McLeod View Post
Um, no.
Huh, I was told our by our FTA that the local teams got their robots running at Quick Build via PoE. I'll have to clarify how that worked.
2016-Present FTAA
Unread 13-01-2017, 08:25
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
As a test robot, you can put a 2nd battery that only powers the radio. that would avoid brownout problems. If the robot is not moving, then you can plug the radio into an AC power supply. Or, battery->dc to ac converter -> 110v to 12v dc power supply -> radio
Unread 13-01-2017, 08:41
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
If your radio pulls more than 2 amps, it is already broken. The extra ampacity of the PDB just lets the broken radio smoke a little more. The big issue is brown outs will reset the radio. For limited testing I wouldn't have any issues. You can always put an in line fast blow fuse,
Unread 13-01-2017, 09:04
POE setup requires a way to inject power from a VRM into the radio alongside the roboRIO-to-radio Ethernet communications.
Here's an example:
Unread 13-01-2017, 09:32
Brutick's Avatar
Brutick Brutick is offline
E/M/P Mentor
AKA: Brandon Jutras
FRC #1360 (Orbit Robotics)
Brutick is an unknown quantity at this point
Here's an example:
You can use 12V passive PoE to power the radio? The silk screening claims 18-24V PoE only. Unless you're using the 802.3af port which would violate R63?
We're looking into doing this, I ended up ordering some boost converters, but if I don't need them then I'm not going to use them.
Unread 13-01-2017, 10:06
Read the label on the back of the OM5P-AN radio.
Note: This is only for the older OM5P-AN radio. The New OM5P-AC is looking for 24v on the Passive POE port.
POE Input:12-24v in the port closest to the barrel input.
The 802 port wants 48v
