Go to Post One of my management professors taught me this: At all times you are holding a bucket in each hand, one full of water, and one full of gasoline. Management is knowing when to throw which bucket. - Barry Bonzack [more]
Unread 11-01-2017, 16:00
gmalexander29 gmalexander29 is offline
FRC #5000
gmalexander29 is an unknown quantity at this point
Can't find roboRio firmware
I'm following the directions in the control system, but I can't the firmware folder
Unread 11-01-2017, 18:31
Benmw99's Avatar
Benmw99 Benmw99 is offline
2168 Lead Programmer
AKA: Ben W
FRC #2168 (Aluminum Falcons)
Benmw99 is an unknown quantity at this point
Re: Can't find roboRio firmware
I am having the same problem, in the /Shared/Firmware directory it brings me to only contains a folder for CVS config.
Unread 11-01-2017, 22:32
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
This is what it looks like for me (see image). Did you install the FRC 2017 Update Suite?
Unread 12-01-2017, 18:40
Benmw99's Avatar
AKA: Ben W
Meant to put this up last night, but I re-downloaded it from the FIRST site and it worked this time. downloaded from here: http://www.ni.com/download/first-rob...-2015/5112/en/
Unread 13-01-2017, 08:11
The firmware update instructions look like they've been moved from the Getting Started section to the Troubleshooting section. Is there a reason you're trying to update?
