Go to Post Eliminate the scavenger hunt, stop updating the software every two seconds, and make sure your examples and tutorials work. That will help a majority of the people I feel. - sircedric4 [more]
Unread 13-01-2017, 08:46
Ogehsim's Avatar
Ogehsim Ogehsim is offline
Nasty
FRC #2877
Ogehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond reputeOgehsim has a reputation beyond repute
Re: Fueling Scoring Challenge
Originally Posted by BoilerMentor View Post
Supposedly it's 4-5. If the goal is more full it should be closer to 5, because you're less likely to have game pieces "wandering" looking for a slot to drop into in the mechanism inside the goal
A BOILER processes FUEL in to steam at an average rate of five (5) FUEL per second per GOAL, but actual rate is dependent on the amount and packing of FUEL in the GOALS (i.e. the tighter the packing in a GOAL, the faster the FUEL processing rate).
5 is average, but if you jam the thing full (70 max balls for low, 150 max balls for high), it should actually go *faster* than 5/s for the same idea of less time wasted bouncing around before dropping into a carousel slot.
I've heard estimates of anywhere from 8 to 15 balls/s for a full boiler, but I don't have a source for those numbers.
