Go to Post The 3 probably stands for the number of years this season will take off your life - JohnSchneider [more]
Unread 13-01-2017, 01:39
Lorianadonovan's Avatar
Lorianadonovan Lorianadonovan is offline
FRC #3204 (Steampunk Penguins)
Lorianadonovan is an unknown quantity at this point
Smile Autonomous Switch?
This year my team was thinking on having multiple autonomous methods depending on where we were starting on the field/what the teams in our alliance could do. One of the other mentors for the team saw physical switches when she was a judge last year in NJ on some robots. Does anyone know about this? Is there an easier way to have multiple auton methods?
Unread 13-01-2017, 01:40
lethc's Avatar
lethc lethc is online now
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
Re: Autonomous Switch?
Use SmartDashboard
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 13-01-2017, 01:43
lgphoneeric's Avatar
lgphoneeric lgphoneeric is offline
FRC #2996 (Cougars Gone Wired)
lgphoneeric will become famous soon enough
We have usually just had a toggle or selector (or a few) on the dashboard of the driver station that we select depending on what we need to do, or where we need to be in autonomous. Its one of the easy ways we have found to vary the program and its not a lot of extra work for the programmers.
If you have everything under control, something's about to break.
Former FRC Driver, Alumni, Mentor
Unread 13-01-2017, 01:44
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Physical switches are a tried and true method, having been used by teams for over a decade. They will work when mounted on either the OI or the robot itself. During auto when you try to read the state of the OI you get whatever the values were before it went into auto.
Unread 13-01-2017, 01:53
Lili_1868 Lili_1868 is offline
Autonomous Director
AKA: Lili Sun
FRC #1868 (Space Cookies)
Rookie Year: 2016
Lili_1868 is a glorious beacon of lightLili_1868 is a glorious beacon of lightLili_1868 is a glorious beacon of lightLili_1868 is a glorious beacon of lightLili_1868 is a glorious beacon of light
Last season we had a bunch of switches on our driver station and certain configurations were for different modes.
Unread 13-01-2017, 06:50
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
The switches are just treated like another limit switch. We always used rotary switches until our programmers took over the task, but simple on-off switches can be used. One switch = two options. Two switches = 4 options.
Older, but still somewhat coherent.
Unread 13-01-2017, 07:19
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
There are many ways to connect physical switches to your DS if you want to do that vs software buttons on your SmartDashboard. Many revolve around using USB connected I/O boards that mimic an HID class such as a joystick. Or you could just use an old joystick to cannibalize the innards and rewire the button inputs to physical switches on your DS. It'll then show up as another joystick and you just use the buttons as usual.
Unread 13-01-2017, 08:04
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
We use something like this:
https://www.amazon.com/Reyann-Arcade...dp/B00UUROWWK/
It let us build a switch pad with over 15 switches, and connect it to the Driver Station.
Unread 13-01-2017, 08:37
onenerdyguy onenerdyguy is offline
FRC #5929
onenerdyguy is on a distinguished road
We code ours into smartdashboard. Then you can do not only buttons, but speed, direction, drive duration, etc, all tweakable.
Makes tweaking auto mode *alot* quicker.
Unread 13-01-2017, 08:46
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
If you go with switch on the robot method, you wire them the DIO on the robrio. Input to ground (0V). The input reads 1 or true when the switch is off and 0 or false when the switch is on. The DIO can be read when the robot is disabled.
Unread 13-01-2017, 09:22
JordanManowitz JordanManowitz is offline
FRC #3171
JordanManowitz is an unknown quantity at this point
AUTON QUESTION?
At the beginning of the match it states that robots can hold up to 10 fuel and 1 gear. If your team mates don't want to use fuel in auton can a team then have 30 fuel?
Unread 13-01-2017, 09:35
Robo Hamsters Robo Hamsters is offline
AKA: Matthew Vesperman
FRC #4466 (Robo Hamsters)
Robo Hamsters is on a distinguished road
For the past 2 years we have used a rioduino with touchscreen to create an autonomous control panel on the bot.
It gives the programming team additional learning opportunities.
FRC 4466
FTC 7042
2013 Washington DC Regional Finalist
Unread 13-01-2017, 09:47
ToddF's Avatar
ToddF ToddF is online now
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
One of our lessons learned, which we will be implementing next year, is eliminating any reliance on the smart dashboard. We'll be putting our auto mode selection on the robot. We have been burned too many times by a malfunctioning smart dashboard on our control station computer. It always seems to happen at the worst possible time.
I hope to never again have this conversation:
"Why did the robot just sit there in auto?"
"The smart dashboard crashed just before the match, and we didn't have time to restart it."
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 13-01-2017, 09:52
Chris is me's Avatar
AKA: Pinecone
The worst is when, you have one auton you run 70% of the time, but you need a different auton for this match. And THAT's the match where your driver station keeps dropping connection, and you have to use the field's driver station, and SmartDashboard won't load for your robot on that computer, and then you have to go out to the field and move your robot in front of the Sally Port so you can just get two points instead of breaking your arm, and then you don't get the two points anyway. And you lose the match.
Anyhow, not speaking from experience or anything, but consider alternatives for selecting autonomous modes in competition. SmartDashboard is great for practice and development adjustments however.
Coding multiple autons is really easy though. If statements, or switch cases, that call each method depending on the state of a sensor on the robot (e.g. a potentiometer or series of switches), or the state on SmartDashboard.
Unread 13-01-2017, 09:59
Coach Seb's Avatar
Coach Seb Coach Seb is online now
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
any info on using the RIOduino to control the auton would be appreciated...
