Go to Post It's not about taking risks, but more about identifying them (which is the hardest part) and reducing them. - Deke [more]
Unread 13-01-2017, 10:13
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Re: MJPG Streamer input from opencv in C++
Originally Posted by Thad House View Post
Hmm that's interesting. Something I noticed is that you have -std=c++0x set. We build everything with -std=c++1y. That might explain that. Try changing to that. Also if you are interested, at the link afterward is all the compiler options we set. https://github.com/wpilibsuite/Visio...ins/arm.gradle
That didn't seem to make a difference sadly. I also tried adding the arguments you used in your build and no difference. Here is the full output
g++ -std=c++1y `pkg-config --cflags --libs opencv` -Wformat=2 -Wall -Wextra -Werror -pedantic -Wno-psabi -Wno-unused-parameter -fPIC -rdynamic -Wno-error=deprecated-declarations -pthread -I/home/pi/wpiutil/include -I/home/pi/ntcore/include -I/home/pi/cscore/include -L/home/pi/wpiutil/Linux/arm -L/home/pi/ntcore/arm/ntcore/build/libs/ntcore/static -L/home/pi/cscore/Linux/arm -lwpiutil -lntcore -lcscore   -o test test.cpp
/tmp/ccEiQ61k.o: In function `cs::VideoSource::VideoSource(cs::VideoSource const&)':
test.cpp:(.text._ZN2cs11VideoSourceC2ERKS0_[_ZN2cs11VideoSourceC5ERKS0_]+0x44): undefined reference to `cs::CopySource(int, int*)'
/tmp/ccEiQ61k.o: In function `cs::VideoSource::~VideoSource()':
test.cpp:(.text._ZN2cs11VideoSourceD2Ev[_ZN2cs11VideoSourceD5Ev]+0x40): undefined reference to `cs::ReleaseSource(int, int*)'
/tmp/ccEiQ61k.o: In function `cs::UsbCamera::UsbCamera(llvm::StringRef, int)':
test.cpp:(.text._ZN2cs9UsbCameraC2EN4llvm9StringRefEi[_ZN2cs9UsbCameraC5EN4llvm9StringRefEi]+0x3c): undefined reference to `cs::CreateUsbCameraDev(llvm::StringRef, int, int*)'
/tmp/ccEiQ61k.o: In function `cs::CvSource::CvSource(llvm::StringRef, cs::VideoMode::PixelFormat, int, int, int)':
test.cpp:(.text._ZN2cs8CvSourceC2EN4llvm9StringRefENS_9VideoMode11PixelFormatEiii[_ZN2cs8CvSourceC5EN4llvm9StringRefENS_9VideoMode11PixelFormatEiii]+0x5c): undefined reference to `cs::CreateCvSource(llvm::StringRef, cs::VideoMode const&, int*)'
/tmp/ccEiQ61k.o: In function `cs::CvSource::PutFrame(cv::Mat&)':
test.cpp:(.text._ZN2cs8CvSource8PutFrameERN2cv3MatE[_ZN2cs8CvSource8PutFrameERN2cv3MatE]+0x38): undefined reference to `cs::PutSourceFrame(int, cv::Mat&, int*)'
/tmp/ccEiQ61k.o: In function `cs::VideoSink::~VideoSink()':
test.cpp:(.text._ZN2cs9VideoSinkD2Ev[_ZN2cs9VideoSinkD5Ev]+0x40): undefined reference to `cs::ReleaseSink(int, int*)'
/tmp/ccEiQ61k.o: In function `cs::VideoSink::SetSource(cs::VideoSource)':
test.cpp:(.text._ZN2cs9VideoSink9SetSourceENS_11VideoSourceE[_ZN2cs9VideoSink9SetSourceENS_11VideoSourceE]+0x54): undefined reference to `cs::SetSinkSource(int, int, int*)'
test.cpp:(.text._ZN2cs9VideoSink9SetSourceENS_11VideoSourceE[_ZN2cs9VideoSink9SetSourceENS_11VideoSourceE]+0x7c): undefined reference to `cs::SetSinkSource(int, int, int*)'
/tmp/ccEiQ61k.o: In function `cs::MjpegServer::MjpegServer(llvm::StringRef, llvm::StringRef, int)':
test.cpp:(.text._ZN2cs11MjpegServerC2EN4llvm9StringRefES2_i[_ZN2cs11MjpegServerC5EN4llvm9StringRefES2_i]+0x4c): undefined reference to `cs::CreateMjpegServer(llvm::StringRef, llvm::StringRef, int, int*)'
/tmp/ccEiQ61k.o: In function `cs::CvSink::CvSink(llvm::StringRef)':
test.cpp:(.text._ZN2cs6CvSinkC2EN4llvm9StringRefE[_ZN2cs6CvSinkC5EN4llvm9StringRefE]+0x30): undefined reference to `cs::CreateCvSink(llvm::StringRef, int*)'
/tmp/ccEiQ61k.o: In function `cs::CvSink::GrabFrame(cv::Mat&) const':
test.cpp:(.text._ZNK2cs6CvSink9GrabFrameERN2cv3MatE[_ZNK2cs6CvSink9GrabFrameERN2cv3MatE]+0x38): undefined reference to `cs::GrabSinkFrame(int, cv::Mat&, int*)'
collect2: error: ld returned 1 exit status
Makefile:11: recipe for target 'test' failed
make: *** [test] Error 1
