Go to Post Our robot name is currently "Subject to Change". - JesseK [more]
  #31   Spotlight this post!
Unread 13-01-2017, 00:19
AcidWombat AcidWombat is offline
FRC #0971
AcidWombat is an unknown quantity at this point
Re: Realistic high goal scoring rate
Originally Posted by Kevin Sevcik View Post
At 25 ft/s, that's about 12 lbs of thrust. I don't think you'll be going to space today with that engine.
Nah. We'll just fix it in code
  #32   Spotlight this post!
Unread 13-01-2017, 01:03
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Anybody tested the amount of bounce the balls have against the entrance?
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
So I got my jacket back, but it turns out the "W" in WPI doesn't stand for that steak sauce I can't pronounce.
Play is for kids this is serious...
  #33   Spotlight this post!
Unread 13-01-2017, 10:25
rick.oliver's Avatar
rick.oliver rick.oliver is offline
Mentor - Retired
AKA: Pap
rick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond repute
How fast is the ball traveling at the apex of your trajectory? The slowest speed on your trajectory is what you should use with pitch to calculate balls per second.
The model is simple and does not calculate the influence of any drag or lift based on ball spin. In terms of rate, I use the muzzle velocity and pitch as representative of the rate of the balls leaving the shooter. Assuming all balls will have the same velocity profile and land in the Boiler, then what goes out of the shooter at a specific rate gets scored at the same rate. Right?
And yes, the feed rate to the shooter is the rate limiting step. Recognize, too, that feeding multiple balls to a multiple-ball wide shooter will increase the discharge rate. It may also create in-flight interactions which could reduce efficiency of scoring.
  #34   Spotlight this post!
Unread 13-01-2017, 10:35
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
I'm thinking the best teams will be around 10 balls/second. During our Ri3D Testing, we were around 1.25 balls/second. This was only with 1 shooter on our robot, and a fairly unaggressive agitator. I imagine some teams will have three or more shooters on their robot and very aggressive agitators.
We're going to be seeing some robot machine guns out there... this game is going to be a fun one.
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
  #35   Spotlight this post!
Unread 13-01-2017, 10:37
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Those balls aren't traveling at a constant speed, even without drag. If you shoot a ball straight up, it doesn't keep going at the same speed, gravity slows it down. Vertical speed drops to 0 at the top of the arc. At the top of the arc, the balls are closer together because they only have the horizontal component of velocity left. At 86 degrees, you don't have much horizontal component. Specifically, 15 in/s. So you can only shoot 3 per second in a straight line without a traffic jam in mid air. There, I checked your math for you.
  #36   Spotlight this post!
Unread 13-01-2017, 10:39
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
and this is why I'm hoping most shooters are shooting NOT from the front of the boiler, but instead further back
___________________
- Tennyson, Ulysses
  #37   Spotlight this post!
Unread 13-01-2017, 10:42
NathanStro's Avatar
NathanStro NathanStro is offline
Webmaster for 5980
AKA: Nathan Strodtbeck
FRC #5980 (East Grand Rapids Robotics)
Team Role: Webmaster
Rookie Year: 2016
NathanStro is an unknown quantity at this point
I would take a bet and say 3 balls a second will be the average scoring rate. Just a thought though.
Its not about the robot
  #38   Spotlight this post!
Unread 13-01-2017, 12:59
Point blank shooters need to be 2 or 3 wide to make any sense, honestly.
  #39   Spotlight this post!
Unread 13-01-2017, 13:05
SM987 SM987 is offline
AKA: Stephen McKinney
FRC #0987 (The High Rollers)
SM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond repute
I'll take 3 accurate bps over a spray and pray any day.
Attending:
2017 Utah Regional
2017 Las Vegas Regional
2017 FIRST Championship Houston
Team 987 - The Highrollers - Las Vegas, Nevada
  #40   Spotlight this post!
Unread 13-01-2017, 13:14
Professional Stat Padder
In this game, I don't know. If you're shooting at 3 bps, it takes you 16 seconds to shoot a Hopper's worth of balls for 16 points. If you shoot at 10 bps at 50% accuracy, you take 5 seconds to shoot a Hopper's worth of balls for 25 balls or 8 points in 5 seconds. It obviously depends on the accuracy and the shooting rate, but I'd take the second robot in this case.
(2015-Present)
  #41   Spotlight this post!
Unread 13-01-2017, 13:37
especially with a fast ground pickup. Shoot two hoppers of balls, pickup your misses for cycle 3.
I think really effective shooters will either have figured out the distance, speed, accuracy problem, or will shoot layups massively quickly with open top hoppers to recycle the misses. If it takes you 5 seconds to empty your hotter, your first misses are already back in it by the end.
  #42   Spotlight this post!
Unread 13-01-2017, 14:00
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
I consulted a very, very intelligent aero friend of mine and called in a favor. His model indicates an optimistic 7 bps directly in front of the goal from a single stream shooter. Coincidentally the tube below the funnel will accommodate 3 fuel with 1/4" between game pieces and between game pieces and the wall. I'm seeing something on the order of 18-21 fuel per second in our future potentially. I will go on record as saying that you need some kind of metering ahead of your shooter and that interface will be EXTREMELY critical if you're aiming for this kind of Lunacy™.
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
2015-Present Ri3D Team Indiana - Mechanical and Fabrication
  #43   Spotlight this post!
Unread 13-01-2017, 14:20
Once you work that out, you should wind it up to 8 or 9 per stream, just for the video of the midair traffic jam falling back on your robot.
  #44   Spotlight this post!
Unread 13-01-2017, 14:26
50% accuracy doesn't qualify as spray and pray for me. If you can find a way in any scenario to more than triple your bps at an exchange of only half the accuracy, I'd take that deal too.
Attending:
2017 Utah Regional
  #45   Spotlight this post!
Unread 13-01-2017, 14:31
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
There's flywheel shooter spray and pray where you pump out as many balls as you can past a flywheel shooter at a somewhat sustained rate for a few seconds in somewhat the same area.
Then there's "I shoot my entire hopper at once" spray and pray where you fling 50 balls into the air at once and hope that a large portion of them land in the goal funnel.
