Go to Post May your shirts be full of buttons, yours inspiration be plentiful, and your error messages be few. - Barry Bonzack [more]
Unread 13-01-2017, 10:49
JohnFogarty's Avatar
AKA: @doctorfogarty
How Spin Affects Fuel Trajectory
In designing a flywheel shooter with my students I've come across something I'm sure many of you have or will discover. Spin causes some pretty weird things to happen to the fuel as they are in flight to their destination.
What I'm looking to do is increase consistency in my shots and I've already got pretty tight control of the RPM of the flywheel.
This suggestion was mentioned by another mentor that works with my team and I wanted to pass it along for thought and clarification as I work today.
Apparently when you use a flywheel shooter with just a backplate as the arc/curve you lose some of the energy and get less consistent flight paths with the balls because some of the energy you are trying to impart on the ball as kinectic energy is lost as rotational energy....ie spin on the ball. So the idea is instead of having a curve of plastic you instead have a arc made up of a bunch of small wheels, rollers, something of that sort so that you balance out the rotational energy and the ball simply flys up with no backspin....which could be a good thing especially with the fuel balls. The only reference design where I noticed a team had thought of this and were succesfully able to counteract the spin from their flywheel was team 1717 in 2014.
https://www.chiefdelphi.com/media/im...fe76bdff_l.jpg
I'm not an ME so I hope I'm not explaining things too incorrectly, but I thought this was interesting.
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
Unread 13-01-2017, 11:00
Mark Westwig's Avatar
Mark Westwig Mark Westwig is offline
FRC #0639 (Code Red Robotics)
Team Role: CAD
Rookie Year: 2015
Mark Westwig is an unknown quantity at this point
Re: How Spin Affects Fuel Trajectory
Team 639 is prototyping a very similar type of shooter. Our left to right consistency is within a half of a foot every shot, but our front to back is all over the place. We were using an 8" rubber treaded wheel for ours, can I ask what type and size wheel you were attempting it with?
My views do not necessarily portray the views of Code Red Robotics (639) or FIRST.
Unread 13-01-2017, 11:05
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Apparently when you use a flywheel shooter with just the the a backplate as the arc/curve you lose some of the energy and get less consistent flight paths with the balls because some of the energy you are trying to impart on the ball as kinectic energy is lost as rotational energy....ie spin on the ball. So the idea is instead of having a curve of plastic you instead have a arc made up of a bunch of small wheels, rollers, something of that sort so that you balance out the rotational energy and the ball simply flys up with no backspin....which could be a good thing especially with the fuel balls. The only reference design where I noticed a team had thought of this and were succesfully able to counteract the spin from their flywheel was team 1717 in 2014.
Traditionally teams will intentionally put backspin on a ball to get more air time without the ball dropping into the goal. The spin energy you're putting into the ball helps create lift on the ball due to the magnus effect. This can help to increase shooter accuracy when aiming in a vertical hole in the wall because you have a flatter trajectory. Shooting into a horizontal hole with a ball that has holes means your mileage may vary.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 13-01-2017, 11:11
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
I believe that normally backspin will cause the object to take a flatter flight path (which would make scoring more difficult). Perhaps forespin would cause it to drop.
Unread 13-01-2017, 11:21
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
1717's shooter is powered on the backspin. If the rollers spin freely, ball will just simply spin freely without going anywhere.
The hood imparts a force and must do that in order to get the ball out, otherwise you're just exerting a torque on the ball.
Formula SAE is now the thing I do. #becauseRacecar
But I'll still be a mentor for like, forever.
Check out what I'm up to: http://ppi.ddns.net/blog
"So, wait, what kind of engineer are you? Mechanical? Electrical? Software?"
"Yeah pretty much."
Unread 13-01-2017, 11:30
AKA: @doctorfogarty
Check out a video of their robot shooting the ball. It flies with no spin at all.
John Fogarty
Unread 13-01-2017, 11:33
Chris is me's Avatar
AKA: Pinecone
That is evidence in favor of his claim, not against. The ball not spinning is a consequence of it being shot from two wheels both moving at the same speed.
For everyone else in this thread: Almost all answers here in this thread are going to be based on prior experience with balls, which have usually been foam balls or inflatable balls. These do not necessarily apply to these balls! Do your own testing to see what spin does to these balls, as it is definitely not exactly the same as 2016 for example.
Unread 13-01-2017, 11:50
AKA: @doctorfogarty
That makes it clearer as to what he meant. I understand now.
John Fogarty
Unread 13-01-2017, 13:04
Lennie Lennie is offline
FRC #5818
Lennie is an unknown quantity at this point
I can confirm as ex-mentor of the now defunct Team 1717 that both the front and back wheels were velocity controlled (so we could control the spin on the ball). As the post below states this years game uses much smaller "whiffle" balls so there are likely major differences.
I am now mentoring team 5818 and we are looking at a "wheel" shooter as well.
