You're so Vexy.
Unread 11-01-2017, 17:41
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: That's a lot of fuel
Originally Posted by Lil' Lavery View Post
No, I meant lift the robot. I'm not going to have a high school students (or adults) carrying a 150 lb robot off a field with tripping hazards littered around it. I've seen a students' knee buckle while carrying a robot before, and I'm not inviting that possibility again.
I think he was suggesting you modify your restriction to not even lifting the robot off the rope/davit till the field is clear of balls. 90-95% of the lifts to get the robot off the davit would be straight up/down, but every now and then someone's going to grab it funny and have to shift weight and step. or the person freeing the rope will have to shift position slightly. That'd be the absolute worst time to step on a ball.
Unread 11-01-2017, 17:44
Originally Posted by Kevin Leonard View Post
Oh jeez I hadn't thought about this situation. Hopefully FIRST will have some sort of solution for quickly clearing balls out of the way for week 1 events, because there's no way we can have students carrying robots through a pile of balls.
Quick, someone slap a mecanum intake and giant hopper onto a handcart! (Seriously, I think HQ should look into something like this. Hoovering 90% of the balls would make field reset a lot quicker.)
Unread 11-01-2017, 17:51
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
WE NEED DOZER!!!!!!! This year more than ever!
Unread 11-01-2017, 18:26
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
He meant that you were underestimating the ability of your robot. Ideally you will be removing it from a hang, and not lifting it from the floor.
Unread 11-01-2017, 19:03
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Seems like each event needs a contest for best ball vacuum for field reset. Points given for ease of use, battery efficiency, and time required to gather balls.
2017 Scoring Model
CAD Library | GitHub
Unread 11-01-2017, 20:09
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
I'm thinking something similar to this floor squeegee, probably with wheels on the far edges and maybe one in the middle to quickly corral the fuel:
Floor Squeegee
Get the fuel pushed away from the bots quickly so removal can happen safely.
I'm also thinking of making a couple of exactly sized boxes to dump fuel into that measures out 50 of them for easy *counting* to put back in the hopper containers. Just fill the box and dump it in. Trying to come up with ways to make my field reset crew jobs a little easier and the new CNC Router that will be mounted in the garage this weekend will need something to work on.
Nate
Unread 11-01-2017, 21:07
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Leaf blowers
Unread 11-01-2017, 21:28
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Unread 11-01-2017, 21:30
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
There's gonna be fuel rolling around the alliance station and loading lanes, as well. You can even so one little fuel go running for his life in one of the field tour videos. Some poor human player is inevitably going to step on the fuel and fall over, probably while carrying a tote full of even more fuel.
This could also be a hazard to pilots... Warning to all human players this year: Watch your step!
Floor Squeegee
A push broom or a big dust mop might work if they would slide on the carpet..
Originally Posted by AndyBare View Post
Leaf blowers
I can't say that's a bad idea...
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 11-01-2017, 21:43
Originally Posted by engunneer View Post
It'd only have to be twice as big and you'd need like 10 of them....
Unread 11-01-2017, 22:11
BigBen's Avatar
BigBen BigBen is offline
FRC #3494 (The Quadrangles)
BigBen will become famous soon enough
Two people with battery pack powered leaf blowers for the win?
http://www.homedepot.com/catalog/pro...compressed.jpg
Unread 11-01-2017, 22:15
Maybe the "fuel picker-upper" is what they left out of the game design manual.
Unread 13-01-2017, 10:42
IowaBoyInMN IowaBoyInMN is offline
FRC #2526 (2526 Crimson Robotics)
IowaBoyInMN has much to be proud ofIowaBoyInMN has much to be proud ofIowaBoyInMN has much to be proud ofIowaBoyInMN has much to be proud ofIowaBoyInMN has much to be proud ofIowaBoyInMN has much to be proud ofIowaBoyInMN has much to be proud ofIowaBoyInMN has much to be proud of
Relevant: https://youtu.be/7t0EtKlQxyo
Sent from my iPad using Tapatalk
Unread 13-01-2017, 11:03
Rombus's Avatar
Rombus Rombus is offline
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
Some other PCH Volunteers and I were discussing a lot of the same suggestions already mentioned here, Then I found this (rather expensive) tennis ball retriever:
It inspired me to make one up for the fuel. I have a very basic sketch and plan down for a version built out of plywood and plexi using polycord to lift the fuel. I'm mainly waiting to make sure that
1. FIRST does not have a better solution for field reset already in the works
2. confirmation of bin size
I was planning on making it push powered, but I'm wondering now if maybe a CIM to drive the collection mechanism... :hmmm:
Unread 13-01-2017, 11:23
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Holonomic Zamboni.
Cue Hockey music ...
Richard Wallace
since 2003
