Go to Post The rule is the rule because it is the rule. - dtengineering [more]
Unread 07-01-2017, 15:41
arsenicCatnip arsenicCatnip is offline
AKA: Wyatt
FRC #2197 (Las Pumas)
Rookie Year: 2015
arsenicCatnip is an unknown quantity at this point
Reserve Gear
What is the reserved gear used for?
Unread 07-01-2017, 15:58
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
Re: Reserve Gear
From a search of the manual for "reserve," it appears that the reserve GEAR is no different from any other gear, except that by rule A05, PILOTS may not remove the reserve GEAR during auto. (Basically, there is one free GEAR for use during teleop.)
--Jacob
Illinois FTC FTA
Unread 07-01-2017, 15:59
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
Re: Reserve Gear
The reserve gear is up in the airship at the start of the match. I cannot be touched by a Pilot until teleop, however. It seems to me the idea is that it can be used in rotor 1 if no robot has an autonomous that delivers a gear, or used to work toward another rotor otherwise as a "free gear".
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 07-01-2017, 16:45
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is online now
FRC #4536 (MinuteBots)
Re: Reserve Gear
Artificially inflating scores.
Unread 07-01-2017, 17:08
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Re: Reserve Gear
First may want to have the center rotor spin as much as possible during the match as a fun visual element and human-field interaction. It also gives the human player some purpose even if all fielded robots are unable to score gears which looks good visually instead of an empty airship.
2016: FRC 865 Mentor
Unread 12-01-2017, 23:36
JasdeepSadam JasdeepSadam is offline
FRC #2656 (Quasics)
Team Role: Driver
Rookie Year: 2016
JasdeepSadam is an unknown quantity at this point
Talking Re: Reserve Gear
The Reserve gear is a gear that sits up in the Airship at the start of a match. Pilots MAY NOT place this gear during Auto. When Teleop begins they can place it. What this means is that if none of your alliance put a gear during auto your team is guaranteed 40pts at the beginning of teleop as the Pilots can put that Reserve gear into the top gear slot(that only requires one gear to turn a rotator). However if 2 gears are scored in Auto, that is 60pts for getting one rotor spinning in Auto and you are halfway done with the next gear set which means that come teleop, pilots can finish that set with the reserve getr and score 40 MORE POINTS for 100 POINTS. Sorry if this got wordy. Hope this helped!
Unread 12-01-2017, 23:41
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Reserve Gear
The real two reasons...from the director
Frank said it was to allow the airship to "take off" you need at least one rotor to "take off" ... so the game made sense, they did not want all three robots hanging ready for takeoff without a spinning rotor.
Also if there were only shooting/climbing bots the alliance could feel better about engaging a rotor and 40 for a feel good moment otherwise real boring for Humans up there. so save that magic moment for just the right time.
Plus if a team forgets , well that's kind of fun to go ughhhh
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 12-01-2017, 23:42
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: Reserve Gear
Because apparently watching someone place a gear is more interesting than just having a zero point match.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 13-01-2017, 07:57
rich2202 rich2202 is online now
FRC #2202 (BEAST Robotics)
Re: Reserve Gear
Plus, per Frank: The scenario of the game is a race to take off. It would be odd for a team to win (fuel/hang points) on an airship that was not capable of taking off, and the other airship could. Thus, the reserve gear ensured that at least the airship was capable of taking off.
Unread 13-01-2017, 12:13
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Re: Reserve Gear
In other words: eye candy.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 14-01-2017, 09:56
paul.dornfeld paul.dornfeld is offline
FRC #5523
paul.dornfeld is an unknown quantity at this point
Re: Reserve Gear
Thank you, Boltman, for that insight from the director.
Is there a link/site from where we can see "Frank's" comments, please?
Unread 14-01-2017, 11:35
Re: Reserve Gear
GameSense S04E01 STEAMworks Holiday Special with Frank! #robotics
https://www.twitch.tv/frcgamesense
Is where I viewed it the other day it says "offline"...I don't see it maybe a youtube later search for it .
Some more highlights unlike Qand A 2017 and the "answer hunt" I'll spill the beans here...
Question 1: What did Frank say?
The answer....
It was a good show for some nice director insights, like the Steampunk theme was in 2 out of 4 ideas kicked around right after last season (they do not plan more than that ahead) ...rose to the top. Disney had less influence last year they did the release video for StrongHold , this year the had a 3rd party do it, disney is mainly for a "good storyline" check. Audience participation went pretty far into the process, then was nixed even though they would have done something with gear contraption choice, but they couldn't work out and make sense. THEY go through the game as HUMBOTS emulating different level team performance capabilities, to try it out on the actual field so from kitbot to 254. They used paint can lids for gears. The small size volumes is to protect HP on field. The general plan for SteamWorks game proposal pretty much made it through the process as is with minor changes.
Unread 14-01-2017, 22:47
FRC #5523
Re: Reserve Gear
Thanks Boltman. Great ideas and resource. From YouTube:
https://www.youtube.com/watch?v=VMhDAbQY9Ac
