Go to Post To go a step further, to be "steam punk", electrics would need to be powered from a steam turbine operated dynamo but electric wiring would still be required to follow all rules as they would apply. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 13-01-2017, 12:59
Dave Hurt Dave Hurt is offline
Mostly Harmless
FRC #6413 (Degrees of Freedom)
Dave Hurt is on a distinguished road
No robot code, but can start it manually
I've setup robotpy 2017.0.2 on my rio and pushed a very simple project to it. Deploy goes ok, but the dashboard says no robot code. So I ssh'd into the rio and started the code manually and then everything started working. Dug around a little bit and I can't find a cause for it, anyone have any thoughts? Thanks!
