Go to Post Stop being LAWYERS and start being ENGINEERS! - dlavery [more]
Unread 13-01-2017, 14:52
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Thin rope!
We have been discussing on our team how a thin rope will be attached on the air ship. With a thick rope its the knot that keeps it from sliding through the two tabs with the pin through it. If you use a thin rope, do you have to make a really big knot? Or can you make a loop and hook it to something? Anybody out there know? Thanks in advance!
Faridodin "Fredi" Lajvardi KD7WKD
Unread 13-01-2017, 14:57
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Thin rope!
You are required to have a retaining feature greater than 1 inch in your rope.
Originally Posted by I04-E Blue Box
To interface with the field a ROPE must have a retaining feature (e.g. a knot) greater than 1 in. (~25.4 mm) in diameter to interface with the DAVITS (RF).
- Arizona North
Unread 13-01-2017, 15:01
Jonny_Jee's Avatar
Jonny_Jee Jonny_Jee is offline
FRC #2085 (Robodogs)
Jonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to behold
Re: Thin rope!
Take a look at the monkeys fist knot. It's pretty large and depending on the number of windings you do, can be as large as you'd like. Also they look really cool!
Keep It Simple Silly!
Unread 13-01-2017, 15:12
AKA: Ledge
Re: Thin rope!
So if using a thin rope, like 1/8 or 1/4" then you must make enough knots to be greater than 1"? You cannot make a loop to hook it on the airship?
Unread 13-01-2017, 15:20
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Thin rope!
It looks like a Slot that the knot sits in, so if you have a thin rope, with a thin knot, it will slip through.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 13-01-2017, 15:30
chrisrin chrisrin is offline
FRC #4915 (Spartronics)
Rookie Year: 2016
chrisrin is an unknown quantity at this point
Re: Thin rope!
Something like this? http://www.sky-international.com/pro...e-ball-fenders
Unread 13-01-2017, 15:32
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Thin rope!
Originally Posted by chrisrin View Post
that is not a legal rope component.
Unread 13-01-2017, 15:33
Rookie Year: 2016
Re: Thin rope!
Just realized those things are huge. Some shaped like that would work. Maybe a disc swing could be used as the top anchor? Or would that be too big?
Unread 13-01-2017, 15:37
Rookie Year: 2016
Re: Thin rope!
Yes if the larger-than-1-inch retaining feature must be part of the ROPE, then I guess a knot it is.
Unread 13-01-2017, 15:38
EmileH's Avatar
EmileH EmileH is offline
#dontbelarge
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Re: Thin rope!
It is not made of non-metallic, woven fibers, so it is not legal to be a part of the rope.
2016-present: High School Student, FRC 1058 PVC Pirates
Unread 13-01-2017, 15:51
AdamHeard's Avatar
Lead Mentor
Re: Thin rope!
We're looking at a .301" diameter rope a that should spool very nicely, but I'm afraid of looking back and thinking we could've done more.
Unread 13-01-2017, 16:11
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
Re: Thin rope!
Unread 13-01-2017, 16:19
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Thin rope!
Originally Posted by s_forbes View Post
Can you please convert lmao to SI units (m/sec^2)?
Richard Wallace
since 2003
Unread 13-01-2017, 16:30
Re: Thin rope!
+1^
The image above is a three-strand monkey's fist in 3/8" braided polyester rope. Knot diameter ~2.3 inch.
Rep points to the first student who ties one, measures the length of rope required between the two taped points, and posts a correct result (+/- 30 mm).
Richard Wallace
since 2003
Unread 13-01-2017, 16:47
jnicho15's Avatar
jnicho15 jnicho15 is offline
AKA: Dan
FRC #0548 (Robostangs)
Team Role: Electrical
jnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nice
Re: Thin rope!
Originally Posted by Richard Wallace View Post
...3/8"...
...~2.3 inch.
...(+/- 30 mm).
One of these things is not like the other...
2014: MIHOW DCA, Finalist
2015: MISOU Finalist; MILIV DCA, Winner; MIBED Winner; MICMP Winner, Engineering Excellence
2016: MISOU KPCB Entrepreneurship Award; MILIV DCA; MICMP 16th Alliance- 8-F winner
