Go to Post However, the best responses come with patience. It might be a couple of days before you get a good answer or it could be 10 minutes. - Molten [more]
Unread 13-01-2017, 16:05
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Rapid fuel feeding into shooter
Originally Posted by Cothron Theiss View Post
Do you mind sharing some of the specs on motor, gearing, and wheel?
The shooter wheel is a 6" AM wheel, geared down roughly 4:1 from a CIM (It goes way too slow, but that was the quick easy way to build it at the time). The backing material for the shooter is a slightly flexible corrugated composite hi-tech material (cardboard). The recycling can is just a recycling can with a hole in it. Stick some shelf liner on the end of a drill (high speed preferable) and watch the balls fly out!
