Go to Post Brandon, can you make some sort of mind-reading device that i can just think "portal" and i'll go back? - Tom Schindler [more]
Unread 13-01-2017, 16:05
cnc4 cnc4 is offline
FRC #2231 (OnyxTronix)
Rookie Year: 2015
cnc4 is an unknown quantity at this point
Lets talk about the long deploying time
I am using java to deploy code to the robot and it's taking about half a minute to deploy in the best case scenario. Before 2017 season it was 15 - 20
now it's not a reasonable run time, I mean I didn't check the build process but running a fresh code which takes about 40 sec can surely be reduced.
Does it copy all the 3rd party lib into the robot every time?
I am intrested in hearing your thoughts guys and build time on your programming language.
Unread 13-01-2017, 16:09
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
Re: Lets talk about the long deploying time
I have also noticed an odd increase in Java deployment time this year. In 2013 it took around 30 seconds, 2014 down to 20-25ish, and 2015 was down to times around 10 seconds. I am not sure about last year's average time, but this year our deploy times have all been longer than 30 seconds. One possible reason is that we are also deploying a CAN library for our speed controllers this year, but I doubt it's the sole reason, and I'm not sure of any other reasons off the top of my head.
Unread 13-01-2017, 17:25
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
This year's deploy scripts makes more ssh calls than it previous made, and if your mDNS resolving isn't particularly fast, it might be the cause. You can test this (ish) by opening a command prompt and doing a 'ping' of roborio-XXXX-frc.local, where XXXX is your team number, if it takes awhile for it to figure how to resolve that address, that could be the culprit.
Unread 13-01-2017, 20:42
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
Regardless of mDNS lookup times, the additional SSH calls are significant on their own and can easily add at least 1/2 to 2s each to setup/teardown.
I haven't looked at how many more SSH calls there are this year, but I suspect that's a major reason, if not the major reason.
Unread 13-01-2017, 20:55
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
Do you know if it's possible to automatically fall back to static IP?
FRC 2576 2015-2016: Mentor
FRC 2576 2013-2015: Programmer & Chairman's Presenter
Los Angeles Regional 2014: Regional Chairman's Award
Unread 13-01-2017, 21:15
snekiam snekiam is offline
FRC #3322 (Eagle Imperium)
snekiam has a spectacular aura aboutsnekiam has a spectacular aura aboutsnekiam has a spectacular aura about
You could add a static route to your hosts file
Unread 14-01-2017, 02:59
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
GradleRIO has recently been updated to be 2017 compatible. Deploy times are anywhere from 5-15 seconds. For each deploy, there are only 3 ssh sessions (one for discovery, one for NI utils, one for user code), and libraries are only deployed if they have changed or have not been deployed before (e.g. wpilib, opencv, talonsrx, cscore, etc).
You can see the project here: https://github.com/Open-RIO/GradleRIO
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
Unread 17-01-2017, 00:33
Hess1113's Avatar
Hess1113 Hess1113 is online now
AKA: Christopher Hess
FRC #0291 (CIA)
Rookie Year: 2017
Hess1113 is an unknown quantity at this point
I use LabVIEW and one simply edit to your code and you have to build it and Run as startup. This take about 3-5 minutes but one main issue is you have to sit next to your computer due to a couple of warning messages appearing.
Unread 17-01-2017, 16:15
Rsave7 Rsave7 is offline
Memer
AKA: Ryan
FRC #0379 (The RoboCats)
Rookie Year: 2015
Rsave7 is an unknown quantity at this point
Yup.
Thats one of the infinite downsides to using labview. We really need to switch soon!!
“Scientists discover the world that exists; engineers create the world that never was.”
― Theodore von Karman
Unread 17-01-2017, 21:18
The Doctor's Avatar
The Doctor The Doctor is offline
Robotics is life
AKA: Hackson
FRC #3216 (MRT)
The Doctor is on a distinguished road
If you really want to, you could submit an issue or pull request to the official WPIlib. Clearly, as Jaci points out, it could be faster with the right code.
https://github.com/wpilibsuite/allwpilib
Robots + Python + pentesting == me;
Blog ~ GitHub ~ Keybase
If you have a pressing issue to discuss with me, kik me at slush.puddles since I don't check CD very often.
Unread 17-01-2017, 21:25
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
The deploy stuff is in the Eclipse plugins project
Java deploy tasks are here (build.properties and build.xml)
C++ here
WPILib
GRIP, RobotBuilder
Unread 18-01-2017, 17:57
Specifically for LV users. I just tested the default code which includes vision acquisition and analysis.
A build was 25 seconds. A Run as Startup was 18. The first time I did these things on my new installation it was longer because it is building more things and caching them.
The interactive deploy (pressing the run button) was about 60 seconds when the target was running something else that needed to be canceled. It was 20 seconds on a target where the VIs were reloaded but the target had them cached. The interactive run was 3 seconds for small changes where the Main VI was not closed.
This was on an i5 several years old - $400 laptop.
Greg McKaskle
Unread 21-01-2017, 23:58
c0d3rman's Avatar
c0d3rman c0d3rman is offline
Programming Captain
AKA: Yoni Lerner
FRC #4904 (Bot Provoking)
c0d3rman is an unknown quantity at this point
One thing I found is that using a manual DNS server (8.8.8.8 & 8.8.4.4 for me) made the lookup take significantly longer (40 seconds with, 10 seconds without).
