Go to Post If you have not had a positive experience in FIRST, please don't bring those that have down. - Jeff K. [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 13-01-2017, 12:07
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Value of a Turret in STEAMWORKS
Is a turret worth it in STEAMWORKS? It would allow for quick and fine side to side adjustments on a shooting mechanism that would be more accurate than turning your drivetrain. You can continue to shoot even while pinned at awkward angles as well as many other benefits.
Some cons are that turrets add complexity, it would be hard to use a turret in combination with a wide drum shooter, and there is a perfectly good wall to park against in the key.
When considering shooting volume is far more important than shooting accuracy, is a turret worth it?
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
Unread 13-01-2017, 12:19
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Re: Value of a Turret in STEAMWORKS
1241 had a great turret based high goal shooter for Stronghold. At first they would stop anywhere on the field in front of the batter to line up the shot, but teams playing defense quickly learned to disrupt them. So, they started driving up to a wall before lining up their shot, to reduce the impact of defense.
It took a second or two for their camera to acquire its target and align the shooter. For Stronghold this was fine, and rather necessary since if you missed your shot, you had to start all over again. But if the intent is to unload a hopper full of 50-100 balls at high speed, then I question whether it's worth it. In the time it takes to aim the turret you could just as easily start firing and adjust the robot itself.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 13-01-2017, 12:28
BAB the Builder BAB the Builder is offline
AKA: Benjamin
FRC #2994 (Astechz)
BAB the Builder is an unknown quantity at this point
If you are infact using a high speed shooter to unload 50+ fuel in just a few seconds, by the time you have fired, realigned, and continued firing you could have just as easily lined up using a vision tracking/turret, or just have a specific place on the field to shoot from. If you adjust while shooting you would have only a few fuel left in your bot to make much of an impact once lined up.
In 2016 teams would slam into the tower to have a physical lineup or in 2013 when teams would lineup with the pyramid. although not the most elegant strategy, its quick and effective.
Im assuming you are wanting the most points/time spent shooting so although volume is more important than accuracy, there is still a benefit to making the shots count.
2017-?: 2994
Bots for Life
Unread 13-01-2017, 12:41
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
I think the biggest problem with using a turret shooter is the packaging issue. As we've already seen from Ri3D, one of the best ways of packaging a single shooter wheel with a big hopper is to place the wheel beside the hopper along the width of the robot. But if you want a turreted shooter, you're either taking up a lot of space from your available hopper, putting both the shooter and the hopper on the turret together, or doing something even crazier like using the turret inside of the hopper as an integrated agitator. Frankly, I think all of those options are far more trouble that it's worth. Also, I think it'll be very worthwhile for dedicated Fuel bots to be able to catch and recycle their missed shots, and a turret design makes that much more difficult.
Unread 13-01-2017, 12:54
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Are you attempting to build a single stream flywheel shooter with the capability of hitting shots from range while another team is parked in front of the boiler? In that case, I could buy an argument for a turret.
Unread 13-01-2017, 13:16
onenerdyguy onenerdyguy is offline
FRC #5929
onenerdyguy is on a distinguished road
5929 has a functional turret prototype at the moment, and are finding that while it's nice, it isn't worth the hassle. It's currently taking approx 3x longer to get a solid aim and empty the hopper from range as it does to just drive up to the low goal, and unload to the high goal from there.
We're deciding today which way to go. I have a feeling we'll have 2 groups both developing them independently.
Unread 13-01-2017, 13:37
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
It's a lot of robot real estate taken up for not a lot of benefit. You have only 1/3 of the field to shoot from, and most of it is blocked by the airship after all. I see much more benefit in using the space for 2 shooters
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 13-01-2017, 13:39
Robonut
AKA: Mr. Lam
Rookie Year: 2015
Or a larger on board hopper.
Unread 13-01-2017, 13:41
NathanStro's Avatar
NathanStro NathanStro is offline
Webmaster for 5980
AKA: Nathan Strodtbeck
FRC #5980 (East Grand Rapids Robotics)
Team Role: Webmaster
Rookie Year: 2016
NathanStro is an unknown quantity at this point
I would think it is too big a solution for the problem. Just my opinion though.
Its not about the robot
Unread 13-01-2017, 14:50
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Turret is too much real Estate taken up, you could alway just use an omnidirectional drive base.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
So I got my jacket back, but it turns out the "W" in WPI doesn't stand for that steak sauce I can't pronounce.
Play is for kids this is serious...
Unread 13-01-2017, 15:58
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
Arguably an omindirectional drivetrain provides many disadvantages without addressing the advantage of a turret. Good luck trying to align your omni or mechanum drive while being shoved sideways.
Evaluate all of your needs to play the game, and then find the best way to address those needs by weighing the pros and cons of a design.
Unread 13-01-2017, 16:08
bt20304 bt20304 is offline
FRC #2137
bt20304 is an unknown quantity at this point
Lightbulb Re: Value of a Turret in STEAMWORKS
While i agree that an Omni drive train allows better lateral movement, you should think about defendability of a robot on all omni's. That's gonna take a lot to stay put, eventually your battery will dip due to continual load, and when it dips, your shooter could stall as our shooter did in Stronghold!!!
How you package the turret depends on your design and intake, but they can be quite small. As for aiming, our team student captains thought about keeping turret aimed at boiler the duration of match, and using vision only when line of sight and when readying shooter. wouldn't take much. Just a thought though, haven't investigated too much.
Unread 13-01-2017, 16:28
Robonut
AKA: Mr. Lam
Rookie Year: 2015
One idea that we had for Stronghold but never fully pursued was the ability to keep a turret always aimed toward its intended target no matter what the rest of the robot is doing. If you've got a gyro on board then you know what your heading is, and if you know what your starting position was relative to the boiler, then you can move the turret accordingly. Encoders should provide a "good enough" direction such that a vision system could take over when you need to fine tune the aim.
We had our camera mounted on a servo pan/tilt unit and the working idea was that the camera (instead of a turret) would always try to face the tower, so that when we were ready to aim, it would be reasonably easy to find the vision target. Ultimately we opted for a fixed camera angle to keep the code simple as we ran out of integration time.
Unread 13-01-2017, 21:09
Omnis and mechs aren't the only thing that can be pushed around. While a more traditional drivebase might be pushed around less I have yet to see a robot that couldn't be pushed.
From the information I read it tackled the following issues.
1. Turrets add complexity
2. It would be hard to use a turret in combination with a wide drum shooter
Going omni does directly contradict the following part.
"It would allow for quick and fine side to side adjustments on a shooting mechanism that would be more accurate than turning your drivetrain"
Which I completely agree is a real issue but with drive practice that can be minimized (not eliminated but minimized).
Due to the nature of bumpers your ability to shoot "when being pinned" is completely up to the two robots geometry so omnidirectionality does not tackle that issue the way a turret does. That being said re-positioning is a lot quicker when you can strafe.
The final statement that is made does contradict the whole quick and fine side to side adjustments.
"When considering shooting volume is far more important than shooting accuracy, is a turret worth it?"
If you don't care about accuracy as much as volume then don't worry about the turret anyway.
Unread 13-01-2017, 23:40
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
There is a difference between being pushed around just by barely being touched, and having to have a robot ram you to be pushed. There is a HUGE difference in the force needed to push a omni wheel only bot sideways, and a bot with 8 - 4in diameter 2in thick colson's being pushed sideways.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
