Go to Post I have no desire to watch a battle of who sucks less. - Cory [more]
Unread 11-01-2017, 22:08
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Programing linear strafing Xbox controller
Hey CD
Our team has a linear strafing drive this year, but we are having difficulty programing our Xbox controller's joysticks axis. So the left joystick works, both x and y, but our right joystick gives no feedback to the drivers station. Anyone else have a solution to this issue? Does the drivers station not show the right axis but it still works?
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 11-01-2017, 23:10
PopeRyanI PopeRyanI is offline
FRC #2410 (Metal Mustangs Robotics)
PopeRyanI is an unknown quantity at this point
Re: Programing linear strafing Xbox controller
Make sure you reading out the correct axes of the controller. For an X-box controller Right x-axis should be axis 4 and right Y-axis should be axis 5. Hope this helps!
Unread 12-01-2017, 08:45
Depends on which dashboard you are using, but I assume you are referring to the default Dashboard display of the joystick position.
The default LabVIEW dashboard is setup to display axis 0 & 1 from two different joysticks plugged into USB0 and USB1.
To show the two sticks on an xBox create a new LabVIEW Dashboard and change the joystick mapping to the Dashboard display.
It's pretty simple to do.
Unread 13-01-2017, 17:40
messer5740's Avatar
Team Role: Driver
Rookie Year: 2015
I think we are running a new version of labview... got any newer code?
Unread 13-01-2017, 17:59
kingca kingca is offline
FRC #0108 (SigmaC@ts)
Rookie Year: 2015
kingca is an unknown quantity at this point
Are you making sure that they are in the right port on the DriverStation for example like the 0 and 1 port.
Unread 13-01-2017, 18:05
I searched Chief Delphi for the phrase "linear strafing drive", and that phrase doesn't seem to be widely used.
Would you please clarify what you mean?
Unread 14-01-2017, 19:45
messer5740's Avatar
Team Role: Driver
Rookie Year: 2015
Using an H-Drive... like mecanum but with all Omni and an additional center Omni wheel. We still can't figure out how to use the different axis's (axisis?) to straife (arcade drive)
Unread 14-01-2017, 19:58
Using an H-Drive...
That's a widely understood name for it.
axes
Describe your driver interface and you might get some help.
Unread 14-01-2017, 20:38
thatnameistaken thatnameistaken is offline
AKA: Joshua Johnston
FRC #2191 (Flux Core)
thatnameistaken is on a distinguished road
Pro tip: the USB tab of the driver station shows all axes and buttons on your controllers, regardless of how your dashboard is programmed.
Click on the controller you're using and move the sticks around to verify which axis is which and that they're all working.
